ASUS TUF GAMING VG279QM
Discorz
VIP Member
Re: ASUS TUF GAMING VG279QM
Post by Discorz » 09 May 2021, 12:20
If anyone is interested here is how crosstalk looks with ELMB SYNC (Adaptive-Sync + ELMB).
Top, middle and bottom of the screen, 280Hz, middle cyan.
VG279QM @280Hz - Crosstalk TOP SCREEN_jpg.jpg (659.76 KiB) Viewed 38878 times
VG279QM @280Hz - Crosstalk MIDDLE SCREEN_jpg.jpg (828.52 KiB) Viewed 38878 times
VG279QM @280Hz - Crosstalk BOTTOM SCREEN_jpg.jpg (681.82 KiB) Viewed 38878 times
Discorz
VIP Member
Post by Discorz » 12 May 2021, 14:42
And here is how regular ELMB looks (without Adaptive-Sync)
VG279QM @280Hz ELMB - Crosstalk TOP SCREEN_jpg.jpg (634.38 KiB) Viewed 38801 times
VG279QM @280Hz ELMB - Crosstalk MIDDLE SCREEN_jpg.jpg (802.61 KiB) Viewed 38801 times
VG279QM @280Hz ELMB - Crosstalk BOTTOM SCREEN_jpg.jpg (720.66 KiB) Viewed 38801 times
Dreamz
Post by Dreamz » 23 Jun 2021, 08:28
Seeing these images makes me wonder if I really need to spend £300 right now on an upgrade from my overclocked XL2411Z @ 200hz with ELMB...
Motion detail is important to me as is response time, might abuse Amazon's return policy to see how much of a difference (of course going to IPS will have benefits too!)
Discorz
VIP Member
Post by Discorz » 25 Jun 2021, 19:31
Dreamz wrote: ↑
23 Jun 2021, 08:28
Oh, is that 200Hz strobed ufo, captured at bottom of the screen?
I wouldn't recommend upgrading to IPS if u don't mind some of the TN cons like colors, viewing angles and size in this case... XL2411Z doesn't have freesync tho. If you really do need to upgrade consider that XG2431 for premium backlight strobing on IPS.
Dreamz
Post by Dreamz » 28 Jun 2021, 13:34
Yeah thats my Benq XL2411Z with ELMB on @ 200hz - it really is impressive vs the "standard" blur reduction at 144hz.
If it had freesync and I didn't have to mess about with OOR Buster etc I think it would be a keeper for now!
magnum_29
Post by magnum_29 » 10 Sep 2021, 14:40
Discorz wrote: ↑
08 Feb 2021, 17:23
OSD settings:
 - everything stock (Racing Mode, Contrast 80, Adapive-Sync ON, HDR off) except Brightness 10, Color Temp. > User Mode > R98, G99, B96 (tftcentral.co.uk calibration)
 - enabling EMLB or ELMB-SYNC automatically changes Brightness to 90.
 - Overclocking ON
 - shipped with firmware MCM103
Setup:
 - ASUS DUAL-RX580-O4G
 - DP cable, not the one included, worked perfect
 - Xiaomi Redmi Note 9S camera
VIEW IN FULL RESOLUTION AND ZOOM FOR BETTER QUALITY!
Strobed vs strobed+vrr vs sample-and-hold ufos (5844x3660), brighter image here: https://i.ibb.co/qnPYs8R/VG279-QM-Blur- ... pg-1-2.jpg
 - 960p/s, middle screen, middle cyan, fullscreen ufo
- overshoot at OD 120 is placed in-between OD 80 and OD 100 (OD 90)
- I'm not sure if VRR is supported with testufo.com, so ELMB-SYNC column might not be representative
- there was no point of recording OverDrives bellow 40
Strobe Crosstalk @120Hz and @280Hz with ELMB (not ELMB-SYNC)
No Frameskipping @280Hz if anyone is into that
Hello, how can i turn on only ELMB, because on my monitor its only saying ELMB -Sync, i have the same monitor but can really figure this out. i would like to try these settings.. :)
Discorz
VIP Member
Post by Discorz » 11 Sep 2021, 08:21
magnum_29 wrote: ↑
10 Sep 2021, 14:40
ELMB is fixed strobing, ELMB-SYNC is strobing + Adaptive-Sync. So just disable Adaptive-Sync and enable strobing (ELMB-SYNC).
batataasada69
Post by batataasada69 » 30 Nov 2021, 14:30
hey i just bought the ASUS TUF GAMING VG279QM could you tell me the best configs for this monitor? for competitive gaming
Discorz
VIP Member
Post by Discorz » 30 Nov 2021, 16:28
batataasada69 wrote: ↑
30 Nov 2021, 14:30
Here ya go:
viewtopic.php?f=2&t=9167
Discorz
VIP Member
Post by Discorz » 15 Mar 2022, 14:59
Fix VG279QM and VG259QM high 60 Hz input lag with QFT/LARGE VERTICAL TOTALS!
From my testing latency was reduced by ∼32 ms.
Formula for Large Vertical Totals:
Desired Vertical Total = (Original Vertical Total) x (Original Hz) / (Destination Hz)
*keep adjusting VTs until horizontal and pixel clock frequency reach it's maximum.
VG259QM will have different parameters, so don't use these exact numbers with 25" model. Just copy your highest Hz parameters.
It is probably not necessary to delete all resolutions, only those associated with 60Hz.
VG279QM VG259QM 60Hz High Input Lag Fix.png (140.04 KiB) Viewed 32667 times
Once you're done reboot your computer (or run restart64.exe to reboot GPU driver) and you're good to go.
