Warlockuy
Post
by Warlockuy » 11 Jun 2021, 07:42
milojr21 wrote: ↑11 Jun 2021, 05:05
Discorz wrote: ↑11 Jun 2021, 01:05
pigzera wrote: ↑10 Jun 2021, 16:58
Its a shame theres no software for this model.
ASUS DisplayWidget definitely doesn't support VG279QM (and VG259QM). I tried it already.
Lucasre5 wrote: ↑26 Dec 2020, 00:34
guys I don't know if this has already been discussed here, but the asus display widget works on the asus vg259qm, you can change the color presets, color temperature, brightness, contrast, saturation and some other things only in the softwere, I just couldn't get it the automatic preset mode according to the program you are running but it helps a lot. I managed to run it by downloading in this model in support / drivers and softweres:
https://rog.asus.com/br/Monitors/Below- ... /helpdesk/
Works on my VG279QM
Yes work in my vg279qm
Very very thanks
Rafael
Max_hz
Post
by Max_hz » 11 Jun 2021, 09:43
Warlockuy wrote: ↑11 Jun 2021, 07:42
Works on my VG279QM
Very very thanks
Rafael
Quick testing on VG259QM, did not test all possibilities but the most important seems to work, good tip!
Discorz
- VIP Member
Post
by Discorz » 11 Jun 2021, 10:10
Just checked other versions. When I open DisplayWidget I get the message monitor is not supported and can only exit the app.
Checked OSD and DDC/CI is greyed out (Display Data Channel / Command Interface is a type of communication between the computer and the monitor). I don't know how to enable it. Some googling suggests hardware incompatibility or graphics driver bug...?
Max_hz
Post
by Max_hz » 11 Jun 2021, 10:39
Discorz wrote: ↑11 Jun 2021, 10:10
Yes indeed DDC/CI needs to be ON, tried with off and got the same message as you, make sure when installing the app DDC/CI is ON.
BTW I use a Nvidia card. DisplayWidget version 4.0.67.0
Max_hz
Post
by Max_hz » 12 Jun 2021, 03:37
Try to disable "adaptiveSync" in OSD, when I enable "adaptiveSync" DDC/CI is also grayed out in OSD
pigzera
Post
by pigzera » 12 Jun 2021, 10:10
The link provided by "Lucasre5" worked for my VG279QM MC103. It just a little buggy, sometimes it shows incompatible display. Make sure to enable DDC/CI in OSD before running the software.
Discorz
- VIP Member
Post
by Discorz » 12 Jun 2021, 12:15
Max_hz wrote: ↑12 Jun 2021, 03:37
Disabling Adaptive-Sync enabled DDC/CI but I still have the same not supported message. That is interesting.
Max_hz
Post
by Max_hz » 14 Jun 2021, 10:18
I am very happy with this version of DisplayWidget, before every time I wanted to play a game I had to mess around with the buttons behind the monitor to set my desired settings but now with a few clicks on the shortcuts of my keyboard I am done, this is so much easier.
It is a pity that Asus has not made this app specifically for the VG259/279 while it is certainly possible.
This version does not work without any problems and not all options are functional (most of them are) but for me the convenience of the shortcuts alone is worth it, definitely recommended.
ziegenpeter
Post
by ziegenpeter » 08 Apr 2025, 22:42
Discorz wrote: ↑12 Jun 2021, 12:15
Hey
did you figured it out how to use display widget with this Monitor ?
Because i thinking about buy this monitor,
but if i couldnt use display widget or any else third party program to control, i wouldnt buy it.
Always use the monitor joystick to control it would be annoying.
Huhu
does your display widget still works with your monitor after some updates ? and could you tell me exactly which options are not working ? would be fantastic if this would work when i buy this monitor.
