Enable Network Card OnBoard Processor to finally fix wierd latency
Re: Enable Network Card OnBoard Processor to finally fix wierd latency
Post by Slender » 23 Aug 2021, 19:56
Unixko wrote: ↑
23 Aug 2021, 04:05
f1ndus wrote: ↑
23 Aug 2021, 03:15
it take time when people will understand everything, what ever you do in window, it was many times tried, this what you tried its basic tweak of placebo effect
yep he is newbie with this problem he will realize soon :)
I find it difficult and at the same time funny to represent your graph in the mousetester
JDoe
Post by JDoe » 24 Aug 2021, 01:01
skkiNN wrote: ↑
23 Aug 2021, 12:21
JDoe wrote: ↑
23 Aug 2021, 05:46
My network adapter doesn't have an integrated on-board processor.
how u know that man? can i ask u guys if z270F got on board network adapter processor for testing that?
Because Realtek chips which are by the way used in most motherboards don't support hardware offload. So unless you have a fancy high end board with an Intel chip don't bother.
UPD: Okay, I googled your motherboard and it appears to have an intel chip so you could try fix from this thread.
Bobo
Post by Bobo » 24 Aug 2021, 02:09
something that actually improves things is to set the Interrupt Moderation Rate to minimal or off
type this in powershell:
Set-NetAdapterAdvancedProperty -Name "Ethernet" -DisplayName "Interrupt Moderation Rate" -DisplayValue "Minimal"
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 24 Aug 2021, 13:27
Bobo
Post by Bobo » 24 Aug 2021, 16:23
yup
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 24 Aug 2021, 16:45
Bobo
Post by Bobo » 24 Aug 2021, 18:40
i messed with most of the settings from there, and the only one i decided to modify was the Interrupt Moderation Rate and i set it to minimal
timecard
Post by timecard » 12 Sep 2021, 12:46
Some more info for you.
https://www.overclock.net/threads/regis ... e.1752848/
https://github.com/djdallmann/GamingPCS ... /README.md
