Enable Network Card OnBoard Processor to finally fix wierd latency
3xil3
Post by 3xil3 » 22 Aug 2021, 22:00
OMG i finall fixed wierd inconsistent mouse and system latency issues. Im not going to get into everything i thought it was power issue with my place.
The problem is windows it uses your CPU to offload network traffic and if oyu push your system you will feel this it even show on latency monitor USB/DX and vidia driver.
It all depends on if your network adapter has an integrated on-board processor, if so it can help process a lot of networking functions. Which will help free up your CPU so it can be use for other tasks and increase performance.
You need to add value in regestry
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
In right windows
right click new DWORD Value names DisableTaskOffload
DWORD Value: 0 = Use NIC Processor, 1 = Disable NIC Processor
I have z490 with intergrated intel 1225v and working
EDIT
Nvidia users use Use NVIDIA driver slimming remove all junk from driver you dont need. Big issue seem to be network traffic IDK somthing with EMI but causing lag nvidia tementry and containers constantly comumicating over intenet.
viewtopic.php?f=10&t=9060&p=71355#p71355
f1ndus
Re: Enable Network Card OnBoard Processor to finally fix wierd latency
Post by f1ndus » 23 Aug 2021, 03:15
it take time when people will understand everything, what ever you do in window, it was many times tried, this what you tried its basic tweak of placebo effect
Unixko
Post by Unixko » 23 Aug 2021, 04:05
f1ndus wrote: ↑
23 Aug 2021, 03:15
yep he is newbie with this problem he will realize soon :)
JDoe
Post by JDoe » 23 Aug 2021, 05:46
My network adapter doesn't have an integrated on-board processor.
skkiNN
Post by skkiNN » 23 Aug 2021, 12:21
JDoe wrote: ↑
23 Aug 2021, 05:46
how u know that man? can i ask u guys if z270F got on board network adapter processor for testing that?
3xil3
Post by 3xil3 » 23 Aug 2021, 19:11
2 days now and everything still great no random mouse floaty feeling this really does work.
I think most new onboard should especally intel if you dont the id go get new nic card to test this out. I think simthing up with windows offloading to CPU is BS possble becasue of all telmentry going on IDK it make sence though all random ness is packets. And my CPU everything look fine IDK I/O issue ive tried everything even built new computer.
After while noticed it would happen when pluged in my network to computer made me think maybe grounloop somthing trust me tried EVERYTHING.
BTW
10900k @5Ghz
RTX 3080 FE
16GB DDR Corsair vengence rgb pro 32GB cl14 oc to 4000 cl16
samsung nvmr
seasonic 850 titanium PSU
Alienware AW2721D
Yagami
Post by Yagami » 23 Aug 2021, 19:16
3xil3 wrote: ↑
23 Aug 2021, 19:11
BTW
10900k @5Ghz
RTX 3080 FE
samsung nvmr
Alienware AW2721D
Perhaps you have "solved" because your problem is not the same as many here.
nyxo100
Post by nyxo100 » 23 Aug 2021, 19:18
3xil3 wrote: ↑
23 Aug 2021, 19:11
BTW
10900k @5Ghz
RTX 3080 FE
samsung nvmr
Alienware AW2721D
yep thanks for the post but i think this is not the same problem
3xil3
Post by 3xil3 » 23 Aug 2021, 19:20
This post not mine but littraly me word by word when explain over year im exhausted talking about im in process looking moving but havent yet.
https://www.reddit.com/r/buildapc/comme ... and_other/
If you have isue then try even if you dont and everything fine worth doing clearly take overhead off CPU seem to fix wierd nvlddmkm.sys latency issue that people say nvidia driver related.
3xil3
Post by 3xil3 » 23 Aug 2021, 19:37
Also FYI and i didnt know this but by default windows is set up to use your CPU for network overhead regardless if lan cabple read up about it it.
This why everyone should try it even if lower latency in general
