It happens only in motion and there is no movement to the lines.
Gigabyte M32Q Review
- Discorz
- VIP Member
Re: Gigabyte M32Q Review
Verneclover
vizionblind
HELLO. You mention to use the balanced setting but RTNGS recommends picture. thoughts?
- Discorz
- VIP Member
Both are about the same. Balance just gives it an slight edge and overshoot is minimal.
vizionblind
legend2k
Hi, Thank you for the detailed review!
Did you notice any issue while the LFC was active? like stuttering, etc
Is it possible to lower the VRR's lower limit (to 40fps or less) using CRU? Does it cause any problem?
- Discorz
- VIP Member
Yes, you might notice occasional stutter when LFC toggles on/off. I tried modifying VRR minimums to 30 and 40 and M32Q seems to not like it. Screen goes black bellow 48 fps and will stay black until framerate goes back above 48. Modifying VRR range to higher than 48 values works ok, but still some toggle stutters can be noticed, not always tho. (All tested in Smooth Frog on AMD gpu)
- Discorz
- VIP Member
Turns out M32Q can do 60 Hz Single Strobe VRR. Well kind of. Read more here: viewtopic.php?f=4&t=9801
Fnaticx
Yo i bought this monitor since July 2021 and i keep hearing about Aim Stabilizer Sync and that it works for 85hz the only thing i got is Aim Stabilizer On/Off and every time free sync is On Aim stabilizer turns off so can someone please tell me how to enable Aim Stabilizer (BFI) and Freesync at the same time? can't believe i have the monitor for so long and don't know how to set that up, thank you.
- RealNC
Apparently you need to enable something called "Aim Stabilizer Sync".
