Page 13 of 35
Re: Asus XG27AQDMG Discussion
Posted: 23 Nov 2024, 11:54
by RealNC
Chief Blur Buster wrote:
22 Nov 2024, 20:29
RealNC wrote:
22 Nov 2024, 14:46
No frame skipping.
You might see bright squares (frame duplicating).
Yep. Just like with the mouse cursor test, some squares are bright:
RealNC wrote:
22 Nov 2024, 14:46
Also, I get the exact same behavior in the 240Hz mode if I edit it with CRU and reduce VT or the pixel clock. I would guess Asus ships the monitor with 180Hz timings that are not compatible with g-sync? The problem completely disappears if I disable g-sync in NVCP.
That's some quite interesting buggy behavior.
Perhaps I should relay this to ASUS themselves.
I tried customer support, but unfortunately they didn't seem very interested. I'm not sure they even understood what I'm talking about :P
Have you tried upgrading to the latest firmware?
Yes, there were two firmware upgrades since I bought this monitor. I went from MCM101 to MCM102 on day 1. Then to MCM103 when it was released and is still the latest version.
Posted: 26 Nov 2024, 10:36
by VincentDM
Hey, any of you also have that annoying issue in which the Monitor switch back to full brightness once it woke up from sleep ?
It has been mentioned on ASUS' forums, but as always, ASUS is anything but helpful and don't acknoledge this problem that is multiple months old at least.
This, as well as some other issues, makes me want to try another OLED or even switch back to IPS while It's still time to return it.
Posted: 26 Nov 2024, 21:24
by RealNC
VincentDM wrote:
26 Nov 2024, 10:36
Yes, it sometimes fails to restore settings after waking up from standby mode. It's not just the brightness, but pretty much all image settings. When this happens, don't change brightness. Instead, turn the monitor off and on again with its power button. It will then restore settings correctly.
It's another firmware bug.
Posted: 27 Nov 2024, 00:30
by Teccaneena
Is there any chance there would be a firmware update to address the crushed blacks?
Posted: 27 Nov 2024, 01:39
by RealNC
Teccaneena wrote:
27 Nov 2024, 00:30
Unlikely. From what I can tell, black crush is an issue with OLED in general:
https://www.youtube.com/watch?v=WNZDA9fLDS8
Posted: 27 Nov 2024, 11:31
by Teccaneena
Got it. Yea I was wondering because I also have the LG 27GS95QE, which actually does not have black crush even at 240Hz and I am trying to decide which one to keep.
Posted: 28 Nov 2024, 06:31
by VincentDM
RealNC wrote:
26 Nov 2024, 21:24
Thank for the confirmation. Hopefully this will be fixed shortly..
Edit : Firmware MCM104 has released shortly after my reply, and this issue is stated as fixed !
Teccaneena wrote:
27 Nov 2024, 11:31
I've tried the NoVideo_sRGB Black Crush fix for that XG27AQDMG Monitor, and it's kind of a perfect solution for me. In the Lagom Black Level, I can actually differentiate each Square now. Which makes the OLED Monitor even better in comparison to my previous IPS one.
I can't confirm that this solution is compatible with 10 bpc Color Intensity that I'm setting in the Nvidia Control Panel however. Or maybe the "Display Reset bug" mentioned above cause these unstable results or something. (It's a different topic, but I'm trying to reduce Color Banding).
Posted: 29 Nov 2024, 15:52
by Sh4rx0r
Hi everyone!
Has anyone encountered this issue where grays show up strangely, almost as if they were compression artifacts? In this example, you can see the compression artifacts from the YT video on the IPS panel next to the ASUS, but the ASUS boosts them up like crazy. I haven't seen this happen on other content, but there a few reports on Reddit of people noticing this in games as well.
It happens regardless of modes (SDR, HDR, 8bit, 10bit, DSC ON, DSC OFF, tried it all). Latest firmware, MCM104.
Thanks!
Posted: 29 Nov 2024, 21:27
by VincentDM
Sh4rx0r wrote:
29 Nov 2024, 15:52
Hey, please search online for a topic on Asus' ROG forum called "XG27AQDMG insane banding/posterization".
An user had the exact same issue I believe. I will (tomorrow) check the trailer from your screenshot on my Monitor to see how it look for me.
Edit : so I've checked this, and it looks very similar to yours on my unit. My old and cheap IPS Monitor looks better in comparison.
But I don't know if that "Banding" issue is because of a faulty unit or a weakness of OLED technology.
Because on my phone (Galaxy Note 9), that trailer video looks noticably worse compared to how it's displayed on the ASUS Monitor.
Also, using the Lagom Banding test page, setting the GPU color depth from 8 to 10 bpc does reduce the banding.
Perhaps lot of content, or evens games are limited to 8 bit color depth or something ? I don't know this topic at all, so I'm quite confused.
Does anyone know if it's another issue, or just an OLED weakness ?
Posted: 30 Nov 2024, 18:03
by Smallsee
New Firmware update MCM104
Firmware Update - Bug Fixes and Improvements
1.Fixed the issue of blurry text when the screen ratio was set to 24.5 inches: Resolved the problem where text appeared blurry when the screen ratio was configured to 24.5 inches.
2.Resolved the issue of screen brightness reverting to 100% after standby for 5 to 10 minutes (offrs): Fixed the problem where the screen brightness automatically reverted to 100% when the signal was restored after a standby period of 5 to 10 minutes.
3.Corrected abnormal skin tones and loss of shadow details in HDR mode at 100% brightness: Optimized HDR mode to address issues of abnormal skin tones and missing shadow details when brightness was set to 100%.
4.Modified OSD menu and translation string errors: Corrected mistakes in the OSD menu display and inaccuracies in translation strings.
https://rog.asus.com/monitors/27-to-31- ... desk_bios/
new settings in oled care - screen saver - screen dimming and outer dimming, what the difference?
