The full path to fix the problem.
naporitan
Re: The full path to fix the problem.
Post by naporitan » 18 Oct 2025, 09:12
joseph_from_pilsen wrote: ↑
18 Oct 2025, 08:02
14900KS is not a best cpu for cs2 for a looong time...
But your advice wont work, not your latency to the server but to your opponent matters. If your opponent sits behind lagcompensated 100ms ping wall, you will never have good input vs him which makes high pingers extra annoying. You dodged as fast as he started peeking in your client? Nah, in his you client you didnt even move. You fire back? Not in his client...
This rule isn't absolute. In that case, turn on a VPN and always play with a 150 ping.
fjoecs
Post by fjoecs » 25 Oct 2025, 10:16
Hi, could you please mention what drivers do you update from MOBO page after fresh window reinstall. Also did you disable SMT in bios?
naporitan
Post by naporitan » 28 Oct 2025, 14:13
fjoecs wrote: ↑
25 Oct 2025, 10:16
Hi, I have a ryzen 7 7800x3d processor, you do not need to disable SMT for this processor, since the cs2 game supports SMT and disabling it leads to a loss of performance.
Which drivers should be installed on an amd processor?
chipset
apu
audio
lan
wifi+bluetooth
monitor driver
nvidia or amd driver
Sz3ypy
Post by Sz3ypy » 29 Oct 2025, 02:05
naporitan wrote: ↑
28 Oct 2025, 14:13
fjoecs wrote: ↑
25 Oct 2025, 10:16
chipset
apu
audio
lan
wifi+bluetooth
monitor driver
Are.you sure you have better performance when SMT is on ?? What about Intel and HT ?
