CS GO Input Lag
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 12 Jul 2023, 17:14
delve wrote:
12 Jul 2023, 17:12
What about your friends pc, is he able to play at a high level? Better than you?
Noo friend is level 1 faceit,he cant tell the difference between 60 and 240hz
delve
Re: CS GO Input Lag
Post by delve » 12 Jul 2023, 18:46
try a location where others can perform very well, it is the only thing left for you, i think.
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 12 Jul 2023, 19:00
delve wrote:
12 Jul 2023, 18:46
I think the same,but its hard to find,because i do not know good cs players ;\ anyways if something happen i will post here.
InputLagger
Re: CS GO Input Lag
Post by InputLagger » 13 Jul 2023, 02:20
SKILLEN wrote:
12 Jul 2023, 17:04
Yes, probably there is little improvement from tweaks ,but on already normal gameplay,if you have problem you can't tell the difference.
i'm on this stage where i need someone to discuss - just something that could cause this,not for entire solution,because the problem is weird and unsolvable for now.
Probably its not software - reinstalled win 7,8,10,11,linux many times, tweaks,everything
Probably its not hardware - changed 7pcs and played on 4-5 more ,mice,monitors,keyboards
Probably its not electricity - no problems offline, problem still here with generator
Probably its not internet - in the moment i have 3isp in my home ,total ISP tried - above 10 + starlink
Travel to 2 different locations both 200km+ from home
If i see someone else wrote all of this i would say the guy is crazy :lol:
Maybe something in the air. Try WiFi, 3g, 4g, 5g
GSM, CDMA jammer. No one tried this still as I can see atm
triplese
Re: CS GO Input Lag
Post by triplese » 13 Jul 2023, 04:21
SKILLEN wrote:
12 Jul 2023, 17:04
Obviously its not hardware/software problem.
Where are your from? Is there any internet censorship in your country?
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 13 Jul 2023, 11:57
InputLagger: i tried wi fi , 3g,4g,5g no difference ;/
triplese: Im from Bulgaria, i dont know about censorship i checked in google > Bulgaria scores as "partly free" in Freedom House's 2015 report, with a total score of 38.[6] In Reporters Without Borders' World Press Freedom Index, Bulgaria is ranked 106th, with a score of 32.91; in the region, Bulgaria comes after Greece (91st) and right before Montenegro (114th) and North Macedonia (117th). Its score is on a steady downward path since the early 2000s (it was 34th on 158 in 2003).
InputLagger
Re: CS GO Input Lag
Post by InputLagger » 13 Jul 2023, 21:54
SKILLEN wrote:
13 Jul 2023, 11:57
Did you mean jammers? I'm not talking about modems / routers
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 13 Jul 2023, 23:25
InputLagger wrote:
13 Jul 2023, 21:54
SKILLEN wrote:
13 Jul 2023, 11:57
I dont know what jammers is ,but im talking about mobile internet 3g 4g 5g phone connected with cable to PC .
I saw many people in forums try this and for few of them it fixed their problem ,but it seems i dont have same problem like them.
InputLagger
Re: CS GO Input Lag
Post by InputLagger » 14 Jul 2023, 10:56
SKILLEN wrote:
13 Jul 2023, 23:25
InputLagger wrote:
13 Jul 2023, 21:54
SKILLEN wrote:
13 Jul 2023, 11:57
I'm talking about these type of devices https://www.dojammer.com/cell-phone-jammers.html
0ka
Re: CS GO Input Lag
Post by 0ka » 14 Jul 2023, 12:11
InputLagger wrote:
14 Jul 2023, 10:56
these devices do not block the signal but create a large amount of noise through which no other signal can pass (imagine that someone starts screaming when you speak, no one will hear you after that)
