CS GO Input Lag
SKILLEN
CS GO Input Lag
Hello,i know there are many threads here(i read most of them),but im not sure my problem is the same(EMI or internet).I started to feel this problem after i sold my 1st PC 2018 April,i returned 2018 October and the problem was here.Like many people here i changed many pcs ,4 monitors,25 mice(literally:D),internet,tried every tweak,fix... The problem is, my mouse running good only offline with bots,everywhere else (mm,faceit,esea,community servers 15vs15 ,10vs10)i have input lag,dm is much better,but still not like offline, i cant explain it ,i struggle to kill from behind,spray transfer is impossible,flicks are impossible ,tracking with crosshair is impossible,people are destroying me even much much lower skilled players than me. On purpose i set my monitor to 60 hz and fps to 60 and joined NA dm server with 180 ping (im in eu) and im much better than with 300fps and 240hz on faceit,mm,esea,its not even close. Temps are good gpu\cpu ~50 .Same with 1.6 i even tried Condition zero. I cant find any logic why this happens ,if someone have ideas,please share.
1st PC 6700k gtx 970 8gb ram ddr3 i never felt this problem doesnt matter its dm or faceit or mm
2nd PC i5 4440 gtx760 8gb ram ddr3 and here problem started,good only offline
3rd PC i5 9600k gtx 1080ti 2x8 3200mhz
4th PC ryzen 3600 rtx 2060 2x8 3200mhz
5th PC ryzen 5600x amd 550(i know:D but market is crazy now,still 200 fps minimum) 4x4 3200mhz
6th PC i9 9900k 980ti
7th PC 12400f 1080ti
f1ndus
Re: CS GO Input Lag
if you read threads then you should know that its impossible to fix it.SKILLEN wrote: ↑14 May 2021, 09:16Hello,i know there are many threads here(i read most of them),but im not sure my problem is the same(EMI or internet).I started to feel this problem after i sold my 1st PC 2018 April,i returned 2018 October and the problem was here.Like many people here i changed 4 computers ,3 monitors,25 mice(literally:D),internet,tried every tweak,fix... The problem is, my game is running normal all the time only in deathmatch servers and offline with bots,everywhere else (mm,faceit,esea,community servers 15vs15 ,10vs10) i cant explain it ,i struggle to kill from behind,spray transfer is impossible,flicks are impossible ,tracking with crosshair is impossible,people are destroying me even much much lower skilled players than me. On purpose i set my monitor to 60 hz and fps to 60 and joined NA dm server with 180 ping (im in eu) and im much better than with 300fps and 240hz on faceit,mm,esea,its not even close. Temps are good.No problems in cs 1.6 and valorant. I cant find any logic why this happens ,if someone have ideas,please share.
2nd PC i5 4440 gtx760 8gb ram ddr3 and here problem started,good only in DM and offline
People tried everything
SKILLEN
Re: CS GO Input Lag
f1ndus wrote: ↑15 May 2021, 11:11if you read threads then you should know that its impossible to fix it.SKILLEN wrote: ↑14 May 2021, 09:16Hello,i know there are many threads here(i read most of them),but im not sure my problem is the same(EMI or internet).I started to feel this problem after i sold my 1st PC 2018 April,i returned 2018 October and the problem was here.Like many people here i changed 4 computers ,3 monitors,25 mice(literally:D),internet,tried every tweak,fix... The problem is, my game is running normal all the time only in deathmatch servers and offline with bots,everywhere else (mm,faceit,esea,community servers 15vs15 ,10vs10) i cant explain it ,i struggle to kill from behind,spray transfer is impossible,flicks are impossible ,tracking with crosshair is impossible,people are destroying me even much much lower skilled players than me. On purpose i set my monitor to 60 hz and fps to 60 and joined NA dm server with 180 ping (im in eu) and im much better than with 300fps and 240hz on faceit,mm,esea,its not even close. Temps are good.No problems in cs 1.6 and valorant. I cant find any logic why this happens ,if someone have ideas,please share.
Yes i read ,but that does not explain why it happens only in faceit,mm,esea,community servers and not in DM or offline or other games.And at the beginning of the round in freezetime or few secounds later i cant feel any problems,but mid round or late its impossible to kill,its like only im slow and my mouse movement is delayed, everything around me is normal.
f1ndus
Re: CS GO Input Lag
On this thing is everything weird bro, and without any explain.. So many players and people trying this shit for yeaaars and no one do not knwo what is causing itSKILLEN wrote: ↑15 May 2021, 11:14f1ndus wrote: ↑15 May 2021, 11:11if you read threads then you should know that its impossible to fix it.SKILLEN wrote: ↑14 May 2021, 09:16Hello,i know there are many threads here(i read most of them),but im not sure my problem is the same(EMI or internet).I started to feel this problem after i sold my 1st PC 2018 April,i returned 2018 October and the problem was here.Like many people here i changed 4 computers ,3 monitors,25 mice(literally:D),internet,tried every tweak,fix... The problem is, my game is running normal all the time only in deathmatch servers and offline with bots,everywhere else (mm,faceit,esea,community servers 15vs15 ,10vs10) i cant explain it ,i struggle to kill from behind,spray transfer is impossible,flicks are impossible ,tracking with crosshair is impossible,people are destroying me even much much lower skilled players than me. On purpose i set my monitor to 60 hz and fps to 60 and joined NA dm server with 180 ping (im in eu) and im much better than with 300fps and 240hz on faceit,mm,esea,its not even close. Temps are good.No problems in cs 1.6 and valorant. I cant find any logic why this happens ,if someone have ideas,please share.
yonaxsangi
Re: CS GO Input Lag
this is problen on the line so we cant fix this problem.
only fix is to buy something that provides clean electricity like “Perfect power box” or some generators.
SKILLEN
Re: CS GO Input Lag
I never tried UPS ,but the whole house have some thing called Electricity save box i think ,which makes electricity stable. I moved my pc to my friend who lives 7-8km away from me ,same problem there. Again if it was EMI or electricity why offline,DM,desktop,everywhere i never have problems.
f1ndus
Re: CS GO Input Lag
Nah, i use UPS Online but without any difference.
Yeah, i tried MY pc and setup on many different locations, everywhere it was bad.
Thats why i can confirm that PC and monitor which are you using in your home is infected by this problem for some time.
I recommend after fix your electricity problem buy new monitor and pc.
Yes this problem is very complicated.
Im not sure but it can have something with this :
https://prnt.sc/12yy4ny
its maybe 10-15 meters from my house, this can be maybe source of my problem, the same problem as your
SKILLEN
f1ndus
Re: CS GO Input Lag
wait, maybe you have only normal electrical tower which is connecting houses with electricity, but theres are high voltage power lines like this one what i posted.. make sure please if its the same High voltage powerlines.. I know many players who have same problem like we and they have something like this around house..
bro i totally understand what are you typing, for me i have the issue everywhere but in offline and DM its littlebit more playable.. i dont know why it happening...
