No FPS gaming possible
- Slender
Re: No FPS gaming possible
for many test and logic, /set no mean /deletevalue
if you feel different tell me
LaggyTyp
My Settings:
The hit reg is wonderful with it!
BUT: Everyone sees me way too fast! I'm running toward a corridor, there are smokes everywhere, I jump around the corner while running, aim down, and the enemy has me in his crosshairs for a long time. It's as if I had already jumped around the corner on the server. WTF?
Code: Select all
1.) All network card options (Device Manager) disabled
a) Interrupt Moderation = On
b) Interrupt Moderation Rate = Off
d) Network card Transmit Buffer (Device Manager) = 1024
e) Network card Receive Buffer (Device Manager) = 2048
2.) REG: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile
a) NetworkThrottlingIndex = 70 (Decimal)
b) SystemResponsiveness = 0 (Decimal)
3.) CMD@Admin: netsh interface tcp set global rsc=disabled
4.) CMD@Admin: netsh interface udo set global uro=disabled
5.) CMD@Admin: netsh interface udo set global uso=disabled
6.) CMD@Admin: bcdedit /set tscsyncpolicy enhanced
7.) CMD@Admin: bcdedit /set useplatformclock no
8.) CMD@Admin: bcdedit /set disabledynamictick yes
9.) Device-Manager: HPET = Disabled
10.) netsh interface tcp set global autotuninglevel=highlyrestrictedBUT: Everyone sees me way too fast! I'm running toward a corridor, there are smokes everywhere, I jump around the corner while running, aim down, and the enemy has me in his crosshairs for a long time. It's as if I had already jumped around the corner on the server. WTF?
Dcyker
It's the same for me in Valorant, people always have an advantage no matter their Ping, they always see me first. I can crouch/jump it doesn't matter they kill me instantly.
LaggyTyp
bcdedit /set disabledynamictick yes + NetworkThrottlingIndex = 70 = Good
bcdedit /set disabledynamictick yes + NetworkThrottlingIndex = ffffffff = Horror
bcdedit /set disabledynamictick no + NetworkThrottlingIndex = ffffffff = Good
BUT WHY?
BUT WHY?
- Slender
try hard disable mmcss service (it include index and sysresp)
LaggyTyp
I can't find the service under Services?
- Slender
LaggyTyp
bcdedit /set useplatformtick yes
When I run this command, my ping drops from ~14 ms to 5-6 ms but the hitreg is then completely broken.
- Slender
LaggyTyp
There's no HPET option in my BIOS. Wouldn't it be sufficient to disable HPET in Device Manager?
Are there any other commands that should be set for this option (combination)?
