No FPS gaming possible
LaggyTyp
Re: No FPS gaming possible
Post by LaggyTyp » 04 Aug 2025, 12:06
New Settings:
1.) All network card options (Device Manager) disabled
a) Interrupt Moderation = On
b) Interrupt Moderation Rate = Off
d) Network card Transmit Buffer (Device Manager) = 2048
e) Network card Receive Buffer (Device Manager) = 2048
2.) REG: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile
a) NetworkThrottlingIndex = 70 (Decimal)
b) SystemResponsiveness = 10 (Decimal)
3.) CMD@Admin: netsh interface tcp set global rsc=disabled
4.) CMD@Admin: netsh interface udp set global uro=disabled
5.) CMD@Admin: netsh interface udp set global uso=disabled
6.) CMD@Admin: bcdedit /set tscsyncpolicy enhanced
7.) CMD@Admin: bcdedit /set disabledynamictick no
Now the TTK and TTD feel normal.
It just saddens me that I could play at 5-6ms, but it doesn't run smoothly, even though the FPS is good. The mouse also feels weird.
bcdedit /set useplatformtick yes
EDIT:
I'd like to understand why it feels so terrible at, say, 10 or ffffffff? Everyone recommends it, but it doesn't work well for me.
Syykfk
Post by Syykfk » 04 Aug 2025, 12:30
LaggyTyp wrote: ↑
04 Aug 2025, 12:06
What is TTK and TTD?
ChristophSmaul1337
Post by ChristophSmaul1337 » 04 Aug 2025, 12:46
Syykfk wrote: ↑
04 Aug 2025, 12:30
Time To Kill and Time To Damage
LaggyTyp
Post by LaggyTyp » 04 Aug 2025, 12:56
Time to Kill and Time to Death.
NetworkThrottlingIndex = 70 (Decimal) = Good
NetworkThrottlingIndex = 10 (Decimal) = Horror
NetworkThrottlingIndex = ffffffff (Hex) = Horror
WHY?
LaggyTyp
Post by LaggyTyp » 05 Aug 2025, 02:52
I forgot to mention two things.
1.) I disabled virtualization in the BIOS.
2.) I disabled the BCLK TSC HW FIXUP option in the BIOS.
I can currently play very fairly. No advantages. No disadvantages. It feels right.
kriegsnake
Post by kriegsnake » 05 Aug 2025, 03:52
LaggyTyp wrote: ↑
04 Aug 2025, 12:56
WHY?
A very common recommendation in many performance enhancement/gaming guides state that disabling NetworkThrottleIndex improves network performance and latency because in theory it should prevent rate limiting and quality of service (QoS) interactions.
The main purpose of NetworkThrottlingIndex is to reduce (rate limit) calls which would otherwise impact real time audio and perhaps cause stutter or other audible artifacts.
Disabling it may increase throughput, but it does not improve DPC latency which is probably more beneficial for lower latency applications such as video games.
Regarding all bcdedit tweaks , I wouldn't touch any of that, unless your ACPI QPC RTC timers( run on Cpu-z ) are in sync.
LaggyTyp
Post by LaggyTyp » 05 Aug 2025, 04:09
I played with the current settings all day yesterday (including during prime time), and it worked fine. I'm not looking for an advantage, but I don't want a disadvantage either. The settings work. I haven't been able to play properly for weeks.
mel
Post by mel » 05 Aug 2025, 05:22
LaggyTyp wrote: ↑
05 Aug 2025, 04:09
Are you sure its the software and not your isp being poo poo from time to time?
Mine acts normal for some time and then this happens for the next 2 weeks
https://youtu.be/diyNDtBYtpk
Id be ok with that if these players were somewhat decent and not 10k elo premier/wood IV in any other game
LaggyTyp
Post by LaggyTyp » 05 Aug 2025, 05:26
The thing is, I can reproduce it.
Windows Stock = Problem exists
LaggyTyp
Post by LaggyTyp » 05 Aug 2025, 06:27
The last few weeks have been unthinkable, and I haven't even made an effort. I've played completely without thinking.
Solo (Trash-Team)
Screenshot (98).png (2.43 MiB) Viewed 4572 times
