ZOWIE XL2566K Discussion Thread [24.5" 360hz TN]
axaro1
Re: ZOWIE XL2566K Discussion Thread [24.5" 360hz TN]
Post by axaro1 » 14 Oct 2022, 08:27
I really want to try 360hz TN but I just can't justify the 650-800€ price tag.
Still no news about other manufacturers planning to use this same panel, I expect a price drop when 480hz will be released.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
Beavern
Post by Beavern » 19 Oct 2022, 05:07
Yesterday I recived the xl2566k and had a go with it during evenings matches a few ive notices while playing with it.
The clearity is much better then the acer 390hz and the 360hz monitors.
No difference in inputlag
Decent colours for beeing TN
The displayscaler is weird/different from previous monitors ive used I cant scale 720p to fullscreen if i use the "aspect ratio" in nvcp, no mather what kind of scaling option i use in the monitor settnings. however if i use fullscreen or gpu scaling then it works.
Ive notice Vertical lines when i aim. Dont know if this is a qc issue and i got a bad batch or if its supposed to be like this.
Dyac+ Can have some "jitterness" to it and mixed with the vertical lines makes the image look aweful.
Discorz
VIP Member
Post by Discorz » 19 Oct 2022, 08:35
Beavern wrote: ↑
19 Oct 2022, 05:07
Vertical lines like this?
Beavern
Post by Beavern » 19 Oct 2022, 09:08
Yes but only in motion, ill try to take a photo
Discorz
VIP Member
Post by Discorz » 19 Oct 2022, 10:31
Beavern wrote: ↑
19 Oct 2022, 09:08
That is classic pixel inversion. Looks like latest gen TN panels are are still prone to it. Its usually most noticeable in very slow and odd number of pixels per frame motion.
Beavern wrote: ↑
19 Oct 2022, 05:07
Dyac+ can have some "jitteriness" to it
That is probably because u are not using it correctly. Everybody is praising DyAc and other blur reduction modes, but I bet 90% of users don't utilize it properly. Keeping framerate unlocked isn't ideal for motion smoothness. You want perfect Frame rate = Refresh rate and flat frame times to avoid jitteriness or tearlines. Especially in low persistence modes where jitters get more amplified. The problem is achieving that perfect sync. There are now couple of third party limiters that can do this, but it can still be unstable and add some minor latency. Thats why DyAc Sync (DyAc+VRR) would come in real handy. Unfortunately they didn't implement such feature.
Frame Rate Limiters and Frame Pacing.png (23.73 KiB) Viewed 9124 times
Good luck achieving perfect sync without VRR.
SvenL
Post by SvenL » 19 Oct 2022, 11:13
Discorz wrote: ↑
19 Oct 2022, 10:31
Wasn't there an Asus monitor where you could use G-Sync and ELMB at the same time (ELMB Sync)? I'm wondering why there is only one monitor that I've heard of that has this particular feature (maybe there are more, I don't know)
But why haven't more manufacturers implemented this feature, is it so hard to develop?
Discorz
VIP Member
Post by Discorz » 19 Oct 2022, 11:56
SvenL wrote: ↑
19 Oct 2022, 11:13
Someone recently asked similar thing here:
viewtopic.php?p=84847#p84847
Idk why none of the manufacturers did it correctly. Either they were limited by something or current implementations were cheaper/easier to do or they just don't know what they are doing.
SvenL
Post by SvenL » 19 Oct 2022, 12:16
Discorz wrote: ↑
19 Oct 2022, 11:56
Ah, thanks for the link, I'll read through that later.
Yeah, that's really a shame. If someone could do it correctly it would be a really great feature.
Discorz
VIP Member
Post by Discorz » 20 Oct 2022, 13:00
Oh great! Thanks for forwarding.
I think top one is 240 and bottom one is 360 Hz. Higher refresh rate always has narrower spacing between frames assuming both are taken at same speed. And GtG proportion is better at 240 Hz.
