Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Misha1337
Post
by Misha1337 » 23 Mar 2025, 16:45
FeelRayvlr wrote: ↑22 Mar 2025, 18:43
Syykfk wrote: ↑27 Oct 2024, 12:04
I have found a solution to the problem of not being able to find the game program in Computer\HKEY_CURRENT_USER\System\GameConfigStore\Children. It is very simple.
1. When opening the game, press win+g to bring up the game bar.
2. Mark the game as "Game" in the game bar.
3. Then you can find the game program in the registry.
1. I downloaded xbox from the microsoft store
2. I opened it and it offered me to install services for the gamebar, I installed them
3. I restarted the PC, opened valorant, win+g, set the gamebar overlay to define valorant as a game
4. I restarted the PC and now the valorant folder and the keys in it appear in the registry. the default value is flags = 11
This was on win10 ?
FYNE
Post
by FYNE » 24 Mar 2025, 02:04
JimCarry wrote: ↑23 Mar 2025, 13:48
FYNE wrote: ↑23 Mar 2025, 12:41
JimCarry wrote: ↑23 Mar 2025, 02:34
ok when you disablefullscreenoptimization does it change from 11 to 211?
No, it stays at 11
So I did some tests and everything works much better on my end than the default value 11, it seems that 511 is slightly ahead of other values. 10% less stutters with 511 vs 11 according to CapframeX. I've tested 11/111/211/311/511/611/711/811/200
Tested with CS2 FPS benchmark map from the workshop
thanks for sharing i also use this map to benchmark,but i deleted children and parents folder long time ago,but the only way to use this tweak was 211, i saw many videos showing this,but 511 i never heard of it thanks.maybe when i re install windows maybe then i can try it,also do you have hags on or mpo disabled?
I have both enabled
