This Is How I Fixed*(asterik!) My Own Input Lag [Update #3]
ACDynamite
Re: This Is How I Fixed My Input Lag [Update]
I just wanted to say thank you very much. I've been struggling with really bad mouse lag/floaty feeling and this is the first "fix" that has made a noticeable difference.
CS2 feels MUCH better after running extensive tests to rule out placebo.
Everything from bios tweaks to reg edits, EMI testing and more - it has all been tried and failed.
THANKS ONCE AGAIN.
Here's my specs if anyone is interested:
- CPU: Intel Core i7-14700K
- MOBO: ASUS ROG STRIX Z790-H GAMING WIFI
- RAM: GSkill DDR5 32Gb (16 X 2) (@6000 XMP Enabled)
- GPU: GIGABYTE GeForce RTX 4070 AERO OC 12G
- PSU: Super Flower 850Watt
- STORAGE: NVMe M.2 1Tb
- Windows 11 Pro (23H2 - up to date)
THANKS ONCE AGAIN.
Which action did you use to fix it?ACDynamite wrote: ↑17 May 2024, 00:27I just wanted to say thank you very much. I've been struggling with really bad mouse lag/floaty feeling and this is the first "fix" that has made a noticeable difference.
THANKS ONCE AGAIN.
I have no input lag, currently mainly researching desync.
According to your version, wmi crashes, but where are these errors displayed and how do they manifest themselves? In the event log?ACDynamite wrote: ↑17 May 2024, 00:27I just wanted to say thank you very much. I've been struggling with really bad mouse lag/floaty feeling and this is the first "fix" that has made a noticeable difference.
THANKS ONCE AGAIN.
After resetting wmi, the registry settings will not be reset?
dermodemon
after cmd command winmgmt /resetrepository i can't run my apps and everything is lagging hard (win11)
Re: This Is How I Fixed My Input Lag [Update #2]
I am very sorry as I didn't mean any harm.dermodemon wrote: ↑19 May 2024, 09:02after cmd command winmgmt /resetrepository i can't run my apps and everything is lagging hard (win11)
Always create a restore point before trying random tweaks as this could happen.dermodemon wrote: ↑19 May 2024, 09:02after cmd command winmgmt /resetrepository i can't run my apps and everything is lagging hard (win11)
This is not a solution to anything and it's not recommended to clear it all the time.
dermodemon
No, it's okay my man, restarted my pc and it is working as always now, don't worry about itFoul Play wrote: ↑19 May 2024, 10:26I am very sorry as I didn't mean any harm.dermodemon wrote: ↑19 May 2024, 09:02after cmd command winmgmt /resetrepository i can't run my apps and everything is lagging hard (win11)
You want to stop the WMI before resetting it to avoid crashes and errors spam.
net stop winmgmt
net stop winmgmt
