Page 3 of 3
Re: Can we clear up the real culprit of input lag? (SOFTLOCKED intel ME/PCH/subsystem)
Posted: 13 Jun 2024, 14:12
by Slender
Hyote wrote: ↑13 Jun 2024, 10:54
Luckily I can have my daily dose of fun after r/shitposting dropped in quality. Almost every topic here is worthy of becoming a copypasta so I collected quite a lot of them if someone would like to see a compilation.
haha, hete, shut up
viewtopic.php?f=10&t=13308&p=103286#p103286
"I found Processor 0 and 1 to be preferrable over Default and the Lock Interrupt Routing gave me the best feel. Emphasis is on feel. Random bullshit go kind of research."
Posted: 13 Jun 2024, 22:19
by Hyote
Slender wrote: ↑13 Jun 2024, 14:12
haha, hete, shut up
You see, I posted some things that weren't based on actual research but they weren't wrong either. At least I continue looking up everything and don't spend 2 weeks replying to nonsense like this.
Posted: 13 Jun 2024, 23:08
by Slender
Hyote wrote: ↑13 Jun 2024, 22:19
haha, hete, shut up
nonsense is use affinity and priority for windows apps
Posted: 14 Jun 2024, 19:25
by 2kmules
Do you actually have a better explanation as to why so many people have unsmooth image, even at high refresh rates and fps? I don't see how anything here, other than some people's comments arguing with each other, is shitpost worthy. I've had many different systems, some with juddery image on that UFO test, some that don't, and this is the most plausible theory I've found as to why it occurs.
Also, does your PC actually pass that UFO test, at 48 fps? This is intended to help people who actually have the issue, or at least get a better explanation as to why input lag is such a widespread issue on modern and powerful hardware. I don't see the point in mocking this theory until we have a better explanation, and electricity is not it for the majority of people.
Posted: 15 Jun 2024, 02:09
by Kipperii
Half a year later: The problem is sperm, please join r/nofap to preserve more sperm for spiritual awakening and strengthen the body's magnetic field to eliminate desync.
Posted: 15 Jun 2024, 03:48
by Slender
Kipperii wrote: ↑15 Jun 2024, 02:09
true
Posted: 15 Jun 2024, 18:56
by 2kmules
[/quote]
Go buy a used motherboard and cpu and see if you get no desync. Compare with a healthy system. It's not complicated.
Posted: 16 Jun 2024, 04:29
by dervu
Go buy this, go buy that. What about actually proving it on more than 1 device (especially modern ones) by author of those videos and not dropping burden of proof on other people? If he is so sure why he doesn't give all information to some technical youtuber with a lot of hardware availibility to test it out?
Posted: 17 Jun 2024, 12:57
by Slender
dervu wrote: ↑16 Jun 2024, 04:29
He's only had this problem for six months, he had no idea about this forum and the input delay. He was just playing games.
Problems with draw distance, the “grid” on the monitor, and ladders on textures have existed at least since 2010. And there is still no solution.
Posted: 17 Jun 2024, 18:12
by Mr1991
If you have a modern Intel CPU with Intels Management Engine built in, you’ve got another complete operating system running that you might not have had any clue was there: MINIX, that’s right.
MINIX the Unix-like OS originally developed by Andrew Tanenbaum as an educational tool - to demonstrate operating system programming - is built into every new Intel CPU. MINIX is running on “ring 3” on its own CPU, a CPU that you, the user/owner of the machine, have no access to.
https://web.archive.org/web/20180102015 ... intel.html
