Page 3 of 3
Re: Another SCEWIN post
Posted: 24 Jan 2025, 02:21
by ahead
Google the meaning of GPIO. If your chip lacks enough physical pins, GPIO lets you use the same pin for multiple hardware functions. Of course, this adds latency—something you'll notice when writing your first firmware for an ARM CPU. But let's face it, you're probably not going to get that far.
Zero tolerance for idiots.
Posted: 03 Feb 2025, 08:38
by Mr1991
Just wanted to bump this with a post, I can’t guarantee this works with every setup, but I can get “FullSpeed” mode on a modern board with no bios changes, basically, on desktop I click the desktop and swirl my mouse, I then press the power button (not hold) on my pc but keep swirling the mouse until the pc is off, turn back on as usual and it puts it into Full Speed mode instead of High Speed (works in USB 3.0 port, my pc doesn’t even have 2.0), it also works on my PCIE usb card, so this makes me think it will work on other setups.
https://ibb.co/LdpypRxN
This is obviously a strange bug, but it works.
Posted: 03 Feb 2025, 23:18
by ahead
USB 3.0 can work in USB 2.0 mode.
Posted: 20 Mar 2025, 06:06
by FYNE
But the 2.0 USB port isn't connected directly to CPU and any guide I was reading suggests you should plug your mouse to the USB ports which are directly connected to the CPU and not USB controller. Also It's kinda strange that I don't have most of the options you guys have but then I have an AM5 board maybe because of that.
Anyone on an AM5 Board who made some changes and had positive results?
Posted: 20 Mar 2025, 12:39
by JimCarry
FYNE wrote:
20 Mar 2025, 06:06
i can upload my scewin file after i export my bios i did not have that option at all.
Posted: 21 Mar 2025, 04:13
by FYNE
JimCarry wrote:
20 Mar 2025, 12:39
FYNE wrote:
20 Mar 2025, 06:06
So you did some changes with SCEWIN on an AM5 board? Do you remember which one?
Posted: 21 Mar 2025, 13:40
by JimCarry
FYNE wrote:
21 Mar 2025, 04:13
JimCarry wrote:
20 Mar 2025, 12:39
FYNE wrote:
20 Mar 2025, 06:06
of course i have list,first i import settings in scewin restart pc and do benchmarks and test,if i like it i wrote it down,but with my new asus mb scewin export maybe 10% of the options,i want to at least disable HPET like on my old mb via scewin with a single restart of the pc.
