Switch to cpu encoding/decoding from gpu in observed settings. You can also record local file to exclude "ISP problem"spkii wrote: β10 Feb 2025, 09:39Ping is OK when streaming, FPS dont dropes lower than 230-240fps on CS2, Valorant or Marvel Rivals... idkgreenenemy wrote: β10 Feb 2025, 08:39@spkii
Check ping wile streaming it could be bufferbloat creating ping spikes or even packet loss both can be perceived as input lag feeling. You can also try to limit your fps to free up some resources for the stream.
the only logical reson behind unexplained input lag and inaccurate sensitivity
InputLagger
Re: the only logical reson behind unexplained input lag and inaccurate sensitivity
- Slender
oh yes, I noticed this back in 2017 when I first decided to turn on the stream. All symptoms have worsened at least 2 times. This is also bad when using any voice application. Most likely something with the UDP packets, perhaps their size. Compare wireshark with and without streaming and post the logs here.
