IPS 240hz -> Acer Predator XB253QGXbmiiprzx ??
b3ka
Re: IPS 240hz -> Acer Predator XB253QGXbmiiprzx ??
Take a look at ufo pictures here: viewtopic.php?t=6581
I'm not sure if you can't achieve such clarity (forget the ghosting effect) on newest IPS displays?
vlkfree
i will try to do my best, but i record with an iphone X
i don't use any lock option etc.
i dont know how to optimise the record
i think the TN monitor is much better for that
but does the difference yield an advantage in game ?
vlkfree
result : the benq is much butter, you can see the eyes clearly
with mine, it's always blurry
b3ka
I think that's the thing about IPS vs TN still in that case, pick your poison as said in my previous threads.
Thank you for checking it and confirming. I think I will have put IPS and TN next to each other and decide.
vlkfree
i think i will return back my ips...
you think that will be an advantage with a TN ? playing FPS only on pc
b3ka
I already 'lost' a week learning about people's opinions with these 240Hz IPS/TN displays and leaning towards one conclusion.
If you only play FPS on PC and can achieve enough FPS then 240Hz TN in 24/27 inches 1080p is way to go.
I use Eizo 2735 (IPS 144hz) for a few years and while it has been very good in colors and motion, using Zowie xl2746s (the newest 240Hz TN Panel) for 1 day changed my whole perception of fast-pace gaming. I have no idea if Eizo is that old in terms of technology or if Zowie was just a proper TN.
I'm still continuing my research and coming up with as stupid ideas as just buying 'the golden standard in TNs' of Zowie XL2546. It just feel a little bad to purchase a product that's been on market already for 1+ year and has upcoming new model of 's' version coming up
vlkfree
you come from a very bad monitor for fps and you have now the best !
i have a TN 1440p, 165hz
i am gonna test it more with the ips at the same time
i can't right now, i'll back for my result
but the benq is better than my actual TN
b3ka
But I returned xl2746s already, it had stuck pixel and they availability in stores is 0 now.
What I worry a lot is that after purchasing fast TN and having some time to play slower games like new Assassin Creed for example I won't stand the image quality.
I would almost purchase 1440p 240Hz TN of Omen X27 but I hear horror stories about grainy coating making it a total garbage.
It's crazy to make a choice at the moment. Good luck with your findings and thanks again for sharing information.
vlkfree
same for me, i hate TN monitors for other games..
i'll buy an oled for all non-competitive games, but in 4K i need to change my 1080
Blehhh
