New 240hz monitor
buddha
Re: New 240hz monitor
https://imgur.com/a/7JZ1GFr - 24g2ze MBR 10,15
Not too sure about crosstalk but 15 doesn't look great to me
Zace
this looks like xg2431. Didn't know MBR on aoc is "this" good.buddha wrote: ↑26 Nov 2021, 16:00https://imgur.com/a/7JZ1GFr - 24g2ze MBR 10,15
- Discorz
- VIP Member
I think you had slower moving ufo speed with MBR 10. Trailing edge should be equally wide as on MBR 15 shot (4 pixels from previous frame at 960pps). Lower speeds have less ghosting/double imaging.
Do two more, perhaps MBR 10 but on top and bottom screen. U can move ufos patterns by clicking and dragging mouse.
XG2431 is far better tuned. But 24G2ZU OD Strong = XG2431 OD OFF (cca). Plus you can't adjust strobe phase on AOC and it doesn't use large VTs.
buddha
I am pretty sure I used the same speed, can't be certain, but I did change a lot of colour settings on this particular mode so I could see (better.) I will do some more with default mode and top and bottom of screen.Discorz wrote: ↑27 Nov 2021, 08:35I think you had slower moving ufo speed with MBR 10. Trailing edge should be equally wide as on MBR 15 shot (4 pixels from previous frame at 960pps). Lower speeds have less ghosting/double imaging.
I am going to return the AOC and HP soon, and maybe the Asus too so if anyone has any requests let me know.
- Discorz
- VIP Member
Just checked. I was wrong. MBR 10 shot is fine. With longer pulse yellow color smears over making the gap look narrow.
I'm real interested in Omen X 27 motion. Do you have it? Its on top of Hardware Unboxed charts but there is not a single pursuit of it online.
Btw, VG didn't turn out good because image is a bit overexposed. That is easily fixable by reducing monitor brightness camera ISO.
Zace
For the HP could you try playing with the contrast like lowering it then upping the brightness to compensate then test the unstrobed ufos. See if you could make the ufo look better.buddha wrote: ↑27 Nov 2021, 10:26I am pretty sure I used the same speed, can't be certain, but I did change a lot of colour settings on this particular mode so I could see (better.) I will do some more with default mode and top and bottom of screen.Discorz wrote: ↑27 Nov 2021, 08:35I think you had slower moving ufo speed with MBR 10. Trailing edge should be equally wide as on MBR 15 shot (4 pixels from previous frame at 960pps). Lower speeds have less ghosting/double imaging.
buddha
https://imgur.com/a/P8QOP3q AOC Strobed top and bottom of screen but I was in a bit of a rush
Thanks for the advice on the VG, I will bear the ISO in mind next time
I am thinking about trying the Omen X 27 so I'll certainly take some shots if I do.Discorz wrote: ↑27 Nov 2021, 11:36Just checked. I was wrong. MBR 10 shot is fine. With longer pulse yellow color smears over making the gap look narrow.
buddha
The pictures I took are with the fps gaming mode which has brightness very high. I would take some more but I don't have time right now and I have to take the Omen back tomorrow.
I'm just gonna put down a couple of thoughts on the Omen, I would say it has the clearest image in motion but it's barely visibly better to me than the AOC. Initially the Asus and AOC looked smeared but I guess they needed to warm up as they got much better. Build quality of the Omen is great and the OSD is solid. It doesn't have strobing or a black equaliser if that is important to you.
- Discorz
- VIP Member
Wow man this is great!buddha wrote: ↑27 Nov 2021, 12:04https://imgur.com/a/P8QOP3q AOC Strobed top and bottom of screen but I was in a bit of a rush
Thanks for the advice on the VG, I will bear the ISO in mind next time![]()
X 27 is probably same as X 25 motion blur wise.
