donger
Re: [Ethernet Onboard-vs-USB-vs-PCIe] I finally found the reason behind my input lag after 6 years
Post by donger » 23 Sep 2026, 13:00
just to drop my 5 cents i have ZERO issues on "x870E MSI Tomahawk WIFI" using ethernet ofc.
mago
Post by mago » 05 Oct 2026, 09:16
https://youtu.be/n8XZ3pAICcc?t=684
πŸ›‘ The FASTEST Gaming PC EVER BUILT. Period. πŸ˜±πŸ‘‘ (LatencyMAXX 2026)
Frame Chasers
β“ˆΠΊπ•€lŁ เ𝓒 α΅—β’ΊΠΌπ•‘Οƒο½’π€π‘β“Ž, lά𝔾 I𝐬 F𝔬ʳ𝔒𝓿ᗴ𝔯
qbBA
Post by qbBA » 06 Oct 2026, 01:01
mago wrote: ↑
05 Oct 2026, 09:16
Frame Chasers
nonsense :D :D :D
vnb
Post by vnb » 06 Oct 2026, 13:12
donger wrote: ↑
23 Sep 2026, 13:00
This is a long thread (21+ pages) but after reading it all, it was pointed out that intel i219v NIC on intel based board (z270, z370 and others) were having those symptoms when the Ethernet cable was plugged in.
Seems like it was an issue specifically related to those older gen boards, or motherboards manufacturers figured out how to properly implement them in newer boards, either way i can confirm that i also does not have issues like this on AM5 motherboard.
Muji
Post by Muji » 10 Oct 2026, 14:23
vnb wrote: ↑
06 Oct 2026, 13:12
donger wrote: ↑
23 Sep 2026, 13:00
I have the same issue with my rog strix b550-f gaming motherboard with the I225-v chip (amd chipset). Whenever I unplug my ethernet, the mouse speed doubles (way more responsive) . I've tried ASIX usb to ethernet adapter. I've tried intel x210 wifi. realtek 8812AU. I think the realtek 8812au wifi adapter felt the best, but it overheats and disconnects. I'm gonna try a Marvell AQC113 and Realtek 8126 pcie ethernet cards when i get the chance and see if its any better.
EDIT: tried the x550-t2 intel chipset pcie card instead. Same issue. I'm not even sure if its the internet connection. I think there is an underlying issue and tweaking with drivers just makes the mouse more responsive for a bit, but the internet driver does make the most noticeable difference for a couple minutes.
