Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
Ghosty_Ind
Post
by Ghosty_Ind » 19 Aug 2025, 08:24
LaggyTyp wrote: β19 Aug 2025, 07:30
I wouldn't complain if it were like that for everyone, but it isn't. Friends from my area don't have any problems. Friends from other countries don't have any problems. Just me.
In the BF6 beta, I saw run-of-the-mill noobs come around the corner shooting. No, not pre-fire! It looked like pre-fire, but it wasn't. I was probably just standing there on their screen, even though I play aggressively and always push.
This topic is giving me gray hair. I'm slowly losing my will and ability to deal with it.
I have this desync problem since 2018. I have played on DSL Internet till 2021. After covid started, I went to my hometown where I got my Fiber connection. Built an okaish PC with i3 10th gen and MSI 1660 Super. After few months, again desync. I thought it was my average hardware, went in to upgrade. I currently have 2 PCs in different cities, both using FTTH connections. I have been diagnosing, trying to fix this fucking, disgusting, pain in the arse, dogshit bitchass problem since 2022, but all in vain. I have spend 3-4 Lakhs INR (3500-4500 US$) just to correct it. My online discord friends think this is placebo effect. I have seen pros and other streamers play. The game runs so fucking smooth with sloths peaking at angles like old man). I am just fucking tired. I play CS2, Valorant, BF6, BF1β¦.All fucking desynced like an old hag.
Tell
Post
by Tell » 19 Aug 2025, 08:26
You said its the same ISP infrastructure but I would still spend the cash to get away from DOCSIS as a troubleshooting step.
Ghosty_Ind
Post
by Ghosty_Ind » 19 Aug 2025, 08:46
I have this problem too..!! I am from India !!
I have been facing this issue from 2018. The desync in CS GO/ CS2/ Valorant/ BF1/ BF6/ BF5.
I understood this is not a placebo and some issue somewhere in my PC/Network/Power since 2021 (Covid phase). The issue is, I realized this and thought there is some faulty part in my PC and spent around 3500 - 4500 $ building/swapping/changing parts, hoping it would solve or change something. But few days after upgrade, the problem came back same as ever.
I have two different PCs (Intel 13700F - Nvidia 4070 & Ryzen 5700X3D - 7700XT) in two different cities, both with different broadband FTTH providers, and facing same issues. I am just tired trying to find the solution day and night for this man !!!
LaggyTyp
Post
by LaggyTyp » 19 Aug 2025, 17:54
My dear friends.
Our common enemy is called
Active Queue Management
https://www.cablelabs.com/blog/how-docs ... gement/amp
https://www.excentis.com/blog/blog-6/ac ... latency-81
It holds back our packets and also bundles them.
60Hz server (tick rate). You send 60 packets per second, which are intercepted by
Active Queue Management and then forwarded in bundles. The same thing happens in your direction. That's why you're scraping extremely fast, and everyone is one step ahead of you.
What can you do? NOTHING!
This technology can be connected to anything, including VDSL, fiber optic, cable DOCSIS, and even mobile networks.
Why do some people have no problems with gaming while others only have problems? Maybe this technology isn't installed everywhere. Maybe it's only used in regions with large populations. Maybe the technology exists everywhere, but it works adaptively and adjusts to the circumstances. I don't know, but there's no solution. Stop gaming.
MontyTheAverage
Post
by MontyTheAverage » 19 Aug 2025, 18:55
Ghosty_Ind wrote: β19 Aug 2025, 08:24
crazy how many many have gone through the same thing becuase of this fucked up problem THAT MAKES NO SENSE. I also tried everything I could but no permanent fix or finding the cause of it....lost lot of days trying to deal with this
LaggyTyp
Post
by LaggyTyp » 19 Aug 2025, 19:36
We can't find anything concrete because it's out of our reach. There are some very smart people here in the forum and on the internet in general, but how are they supposed to find anything if they don't have access to it? The technology I mentioned is most likely in use everywhere, but it only has serious consequences when the area is overpopulated. That means a lot of people on the internet who need a lot of bandwidth. We then feel the negative effects.
Here in Germany, it's 2:30 a.m. now. Gaming works well. The system doesn't need to bundle my packets, etc.
Quickly, another question: How much does ReviOS change the system? How powerful is the network optimization? I actually only use it so I don't have to deal with all the Windows garbage. But I would like to use the network in its original state and tweak it myself.
Ghosty_Ind
Post
by Ghosty_Ind » 19 Aug 2025, 23:42
MontyTheAverage wrote: β19 Aug 2025, 18:55
I think I have found a solution to this based on the possible problems pointed by LaggTyp user.
I have tested it twice during different times and it seems consistent. Will wait it out for 1-2 more days for consistency and then will share with you all. The solution seems very silly, but somehow works exceptionally, and NO, NO SNAKE OIL in BIOS settings or anything, As I already know how many Snake Oils I got while trying to fix this shit !!!
Ghosty_Ind
Post
by Ghosty_Ind » 19 Aug 2025, 23:52
LaggyTyp wrote: β19 Aug 2025, 19:36
Please donβt make any changes for now. I am trying for a resolution and anything you set in the network setting will not help this as I think I understand whatβs causing this on our systems. Of course, it will sound silly, but whatever logical fixes we did, went to gutter anyways
MontyTheAverage
Post
by MontyTheAverage » 19 Aug 2025, 23:52
LaggyTyp wrote: β19 Aug 2025, 17:54
My dear friends.
I don't think so. I tried on several locations across different continents. Same issues. Even on complete different network, PCs. Even on consoles. This problem is much deeper I think or it's simple but we just can't nail it down.
And didn't you say some ram tweaks helped also?
And al
LaggyTyp
Post
by LaggyTyp » 20 Aug 2025, 05:36
@Ghosty-Ind
Please send it to me immediately! No matter how silly it is.
