No FPS gaming possible
Dcyker
Re: No FPS gaming possible
Post by Dcyker » 20 Aug 2025, 07:55
LaggyTyp wrote: ↑
19 Aug 2025, 19:36
We can't find anything concrete because it's out of our reach. There are some very smart people here in the forum and on the internet in general, but how are they supposed to find anything if they don't have access to it? The technology I mentioned is most likely in use everywhere, but it only has serious consequences when the area is overpopulated. That means a lot of people on the internet who need a lot of bandwidth. We then feel the negative effects.
Here in Germany, it's 2:30 a.m. now. Gaming works well. The system doesn't need to bundle my packets, etc.
Quickly, another question: How much does ReviOS change the system? How powerful is the network optimization? I actually only use it so I don't have to deal with all the Windows garbage. But I would like to use the network in its original state and tweak it myself.
It‘s so weird how it works, because for me the later it gets 22:00-01:00+ the People are as fast as ever, I literally have barely a chance, but I‘ve tried Wifi yesterday and for some reason whenever I had packet loss for a bit the Game went super smooth and I was able to kill everyone without any effort, they would come around the corner sit and spray but their bullets wouldn’t even hit me despite me even standing still, which I have never experienced before on my Cable anyone that peeks into me taps me within 1 sec. But once I don’t drop packets my Wifi connection just is as bad as my Cable and everyone fast peeks me.
Ghosty_Ind
Post by Ghosty_Ind » 20 Aug 2025, 10:15
LaggyTyp wrote: ↑
20 Aug 2025, 05:36
@Ghosty-Ind
Please send it to me immediately! No matter how silly it is.
Please give me few more hours. Going to have a gaming session and will confirm if the results are concrete. I’ll share it in few hours.
Ghosty_Ind
Post by Ghosty_Ind » 20 Aug 2025, 10:18
Dcyker wrote: ↑
20 Aug 2025, 07:55
LaggyTyp wrote: ↑
19 Aug 2025, 19:36
Yes I have tried this too. It feels better on WiFi, because what I suspect the configuration for our network Ethernet does not apply for WiFi.
If you’ll go to configure WiFi where we do the INTERP configurations, the options are different. There are limited options and different implementation. However, after testing the fix, it may work better with Ethernet and WiFi occasional jitters and packet losses due to wireless transport of packets will not occur as well.
Please give me few hours guys.
LaggyTyp
Post by LaggyTyp » 20 Aug 2025, 13:04
Brother, I'm waiting here for you. :mrgreen:
Even if it doesn't work. Please tell me.
Ghosty_Ind
Post by Ghosty_Ind » 20 Aug 2025, 13:25
LaggyTyp wrote: ↑
20 Aug 2025, 13:04
Ok, so I tested it, and you won't believe it, it FUCKING WORKED !!!!
Consistent headshots, running enemies headshots, Valorant feels good, Hitreg feels good in CS2, Valo and BF1. I cannot believe it was this silly.. Also, if this does not work, I am very very sorry, I know how much trouble this shit is and how petty we feel.
So going through your post, I saw something like BCLK TSC HW FIXUP and it fixed some of your problems. I turned it off and yes, it did make things smooth for me, but the desync stayed. I returned it back to the default setting and things got shitty again. I also saw your post where you mentioned that AI said your time is 7.16 something seconds behind the NTP. That's how I tried this method and it fucking worked for me...
So what I did is, and what I suggest you also do is to :
1. Revert all the settings back to default. All the dynamictick, plateformclock, or every other snake oil which you tried back to default.. Hell I would say reinstall your OS just to be sure those settings won't hinder the fix.
2. In the right bottom side of the screen where you see the time, right click and select Adjust Date and Time.
3. Before doing any change, I believe you have selected - Set Time Automatically. There is a button - Sync Now, just to align the time with whatever NTP shit is about to give you..Click on it and sync the time....
4. Now, Disable the option of - Select Time Zone Automatically and set it manually to your timezone. Now disable the option- SetTime automatically.
5. Set Date and Time Manually option will be enabled. Open it.
6. Just to be sure, pick your mobile in hand and wait for the minute to complete and move to next minute.
7. Once it moves, set your time to +1 to the current time. E.g. - Current time - 23:48, set it to 23:49 and see the changes reflect properly. I would say your system would pause for a minute, like a stuck window. That is what I believe are the pending packets which your processor ate and got busy.
(Just to explain Point 6 and 7 clearly as someone DM'ed me for not explaining it -
You have your time displayed on your phone - yes ?
Now let's say the computer time is - 23:48 which is around 11:48 night time. Your PC and mobile would be almost showing the same time.
So just to take the reference for setting time manually, you need a clock which is working properly right ? Hence, take your mobile in hand and keep checking the time. As soon as the Minute changes (48 to 49 or 49 to 50), add +1 to the minute and set it in your system. So in mobile and in your current timezone - the time let's say would be 11:50 PM, but on your PC, it should be set as 11:51 PM, which is like 1 minute ahead of your local clock...)
8. After doing this successfully, restart your PC and router both.
9. Start your gaming and report what you see !!! Fingers crossed, you will be in HEAVEN for god sake....
10. I also changed my C-State setting from Auto to Enabled, I if you have that option, do it !! I read somewhere that Auto is bugged, but didn't seem that relevant to me... But not taking any change, I would say to make it same as mine..
This is the fucking silly fixed that worked and I feel like I am the most happy person ever !!!! Thanks to you and your investigations, I was able to fix it. Also, don't believe 80% of what AI speaks, but since it is trained on internet data and hardware capabilities, trust it a little bit XD XD....
What I believe was happening was (Even if I am wrong, I am not a network engineer, but a software Engineer, so I have little idea but not the whole picture) - On our ethernets, there is a buffer queue, which will queue the packets or even store them. Based on receiving from the server with it's timestamp, it matches our Windows timestamp, and wait for it to match it to server timestamp when it was sent - some shit like this "could be" happening. This is all made up and if this is the case, it's totally fucked UP !! Hence the delay, and what we received as - "Normal spikes in our gameplay where everything went stable" is somehow that time or packets got delayed or server tick lagged or some shit due to which it seemed normal.
Now, the packets on client side will be read as soon as they come... Only this explanation made sense to me as to what was happening and what fixed.... If this fixes your Issue too @LaggyTyp, We would have found a big solution which would impact a lot of people getting this issue. Try it and let me know.
Peace out.... All the best.... May the force be with you !!!!!
Ghosty_Ind
Post by Ghosty_Ind » 20 Aug 2025, 13:29
Reply to this message as soon as you read it !!
Ghosty_Ind
Post by Ghosty_Ind » 20 Aug 2025, 14:01
For me, it is 1 min 8 seconds faster than my mobile time(meaning my local time)....
themagic
Post by themagic » 20 Aug 2025, 14:39
Damn maybe im tripping and again on another placebo pills but damn i could feel change and still feel it...
Need more time to test and see if it degrades again or not and for how long lasts...
But damn you might be a Genius if that really FIX and True haha lol :lol:
I already tried many things in the past with NTP sync stuff cause i believed too for some time in that and saw already a Guy who make Video about it and how it affects Hitreg...but he dont show such method and easy steps like you do... :lol:
but here the Video im talking about...
Ghosty_Ind
Post by Ghosty_Ind » 20 Aug 2025, 14:41
themagic wrote: ↑
20 Aug 2025, 14:39
Need more time to test and see if it degrades again or not...
I already tried many things in the past with NPT sync stuff cause i believed too for some time in that and saw already a Guy who make Video about it and how it affects Hitreg...but he dont show such method and easy steps like you do... :lol:
but here the im talking about...
I thought that I am tripping too.... But I tested it for 3 different sessions - with 8 Hours gap in each session - with Peak internet users and less internet users... I confirm that this change impacts all of them....
drosku
Post by drosku » 20 Aug 2025, 14:45
old RIOT repair too did the same thing this is intresting
