Page 25 of 35
Re: Asus XG27AQDMG Discussion
Posted: 29 Apr 2025, 19:03
by soojineee
Hello,
What are the best wipes to clean the XG27AQDMG? I read about the horror stories of smears and smudges left after a cleaning, but I don't really see a definitive answer.
Can I just an alcohol based wipe for the screen? Any recommendations? Thank you!
Posted: 01 May 2025, 02:47
by _zebracrossing666
soojineee wrote: ↑
29 Apr 2025, 19:03
Hello,
use a microfibre cloth and distilled water
the horror stories you hear don't apply to this monitor, it isn't prone to scratches as easily as glossy QD-OLED
Posted: 08 May 2025, 23:48
by dontpokethebear
Rewire wrote: ↑
01 Dec 2024, 12:17
Teccaneena wrote: ↑
01 Dec 2024, 10:25
They mentioned shadow detail for HDR in the notes - does anyone know if the black crush in SDR is fixed?
It's not fixed. You can mend it by doing what the original poster did with nosrgb, but even then I encountered some flaws in actual gameplay scenarios. For example this image from FF16 although there is less "black crushing" there is definitely something wrong with the image. You also lose the oversaturation and vivid colors from base Racing Mode and using Saturation on OSD doesn't really match up with it somehow.
I HAVE THIS ISSUE ON MY SONY M10s
I'm GOING INSANE AHHHH
Posted: 09 May 2025, 00:04
by dontpokethebear
RealNC wrote: ↑
01 Dec 2024, 16:21
VRR throws a wrench in it. The lower the FPS, the more the black levels are raised. You can test this by running a game in Steam and opening the lagom site in the Steam Overlay's browser while VRR is active.
This is driving me CRAZY!!!
on my Sony M10s I am getting posterization that makes this UNUSABLE within the 60-120hz region. Need a fix!!!
Posted: 15 May 2025, 15:49
by Supermodel_Evelynn
I have this monitor and it stinks, worse OLED I ever used the black crush and color banding is awful
Anyway to get 6-bit temporal dithering on an AMD GPU? can you use CRU for this? any guide on this?
Posted: 19 May 2025, 10:44
Supermodel_Evelynn wrote: ↑
15 May 2025, 15:49
Are you the person on Reddit who constantly posts the exact same complaints about this monitor in diff posts for months? Because I don't think you understand how colours work on W-OLED and QD-OLED if you think your 34" QD-OLED had better HDR lol. HDR on QD-OLED monitors is more like SDR+, anything above a 10% APL has the same or worse colour brightness than the average W-OLED monitor. The only time it can be considered real HDR is in 1-2% APL in peak 1000 mode, but that mode's ABL is too aggressive so a lot of people don't even use it.
Plus this is the best W-OLED monitor for HDR that you can buy, in terms of measurements and comparisons against proper HDR mastering monitors. It has the highest colour volume for any W-OLED monitor and beats the LG C4, it has over 500 nits real scene brightness whereas most QD-OLEDs are in the 350-400 range, it has almost flawless EOTF tracking at all APL sizes and is better than most OLED monitors, far better than any QD-OLED monitors EOTF curve.
Lastly, the black crush and colour banding are common issues on W-OLED panels. I'd say colour banding is actually a problem on all OLED panels, but moreso on W-OLED. Thankfully in HDR there is no black crush OR noticeable colour banding(there will be some if you use VRR and have low fps)
Posted: 21 May 2025, 11:10
by HGBowling
Hi, looking for advise:
I have had this monitor for 9 months now. Happy with the performance in HDR, but SDR not so much...
I have an LG OLED CX, and SDR content looks very good and punchy on it (Filmmaker mode and followed HDTVtest's Vincent Theo's advice for accurate picture settings), but on my ASUS monitor SDR looks so dull and a bit washed out... I tried both sRGB Cal Mode and the Racing Mode...
Any advice?
Thanks in advance!
Posted: 21 May 2025, 12:53
by RealNC
HGBowling wrote: ↑
21 May 2025, 11:10
Any advice?
See first post in this thread. Use:
Gaming->GameVisual: User Mode
Gaming->GameVisual->Shadow Boost: OFF
Image->Uniform Brightness: ON
Color->Display Color Space: Wide Gamut
Color->Color Temp: User (100, 100, 100)
Color->Gamma: 2.0 (or 2.2 if you prefer the look of darker shadows)
And use novideo_srgb EDID mode with target set to "sRGB/BT.709".
180Hz and 240Hz should look great. 144Hz and lower will negatively affect the gamma curve. Also you need to get into the habit of manually disabling the novideo_srgb clamp manually before switching to HDR mode and enabling it again after switching to SDR mode.
If you're on an AMD GPU, then use the driver's sRGB clamp instead of novideo_srgb.
Posted: 22 May 2025, 00:37
by Smallsee
ACM - Automatic Color Management in win11
so after enabling this feature i found that the colors have less banding (grey, green) in rtings gradient test
(https://www.mediafire.com/file/4yx45ln4 ... t.tif/file), less oversaturated and looks like srgb but without blackcrush. is there a conflict with the iss profile? have you tested this? as far as I understand, from a certain version of Windows this setting is enabled by default
Posted: 22 May 2025, 11:42
by HGBowling
RealNC wrote: ↑
21 May 2025, 12:53
HGBowling wrote: ↑
21 May 2025, 11:10
Any advice?
Color->Gamma: 2.2
Looks a lot better now indeed, thank you!
