Acer 390Hz monitor - XV252QF
Zace
CRJS so you are saying the latency between motion blur reduction on and off can be felt through gameplay? If so, it must be quite big for it to be felt. Since you got the alienware you must have the reflex analyser, could you test if the case is true and not a placebo?
lizardpeter
Where do you access these pursuit shots? I looked up that video "1624898023991" on YouTube and couldn't find anything.Discorz wrote: ↑26 Aug 2021, 10:46Look mspotatoe, Brandon Taylor used your pursuit shots in his review: https://youtu.be/s4omNr5723I?t=422
OP1 8K V2 | Field75 HE
lizardpeter
AW2521H absolutely has more latency with BFI enabled. According to RTINGs it is 3.8 ms for that specific model. Unlike all of those YouTubers and reviewers who make blanket claims without evidence, I am not going to say that it is not noticeable. I personally think it potentially could be. It also makes it so that no matter what you will always see what's going on 3.8 ms later. Maybe the BFI clarity makes the human element of reaction fast enough to compensate, however. What is very interesting is that the ASUS VG279QM has equal input latency with BFI on and off.Zace wrote: ↑26 Aug 2021, 18:04CRJS so you are saying the latency between motion blur reduction on and off can be felt through gameplay? If so, it must be quite big for it to be felt. Since you got the alienware you must have the reflex analyser, could you test if the case is true and not a placebo?
Inco^
I have an NVIDIA GPU and with my unit it is possible to change Over Drive (Off / Normal / Extreme) while AMD FreeSync Premium is On.ms.potatoe wrote: ↑26 Aug 2021, 16:48![]()
, and to read the rest of the thread.
Hmm? I confirm that in my unit I cannot change the overdrive. Please, can someone with Nvidia GPU try to change overdrive with "Fressync On"?
P̶G̶2̶7̶A̶Q̶D̶P̶ >> 480Hz OLED (1440p)
PG248QP >> 540Hz TN w/ strobing
XL2566K >> 360 Hz TN w/ strobing
XV252Q F >> 390Hz IPS w/ strobing
PG259QN >> 360Hz IPS
XL2546K >> 240Hz TN w/ strobing
Y27gq-25 >> 240Hz TN (1440p)
AG251FZ >> 240Hz TN
LaCie Electron 22 Blue IV >> high-end CRT (140kHz horizontal)
AG251FZ >> 240Hz TN
- Discorz
- VIP Member
1 video here: viewtopic.php?p=68637#p68637lizardpeter wrote: ↑26 Aug 2021, 18:19Where do you access these pursuit shots? I looked up that video "1624898023991" on YouTube and couldn't find anything.
3 videos here: viewtopic.php?p=68678#p68678
2 videos here: viewtopic.php?p=68687#p68687
But use this spreadsheet I made for quick cross-comparison:
https://docs.google.com/spreadsheets/d/ ... sp=sharing
ms.potatoe
Ok, thanks. Then is locked in "Normal" for AMD GPU users ( at least for me, RX 6800XT ) and unlocked with NVidia. Gsync-OD works correctly despite is not officially certified by NVIDIA as G-SYNC Compatible? Please, can you talk about perfomance with Gsync ON OD Normal vs Extreme?
Inco^
I don't know how to use G-Sync, it does not appear in NVCP.
AG251FZ >> 240Hz TN
AG251FZ >> 240Hz TN
Evis
i have nvidia gpu and if i change to amd freesync premium ON, i can't change the overdrive settingsms.potatoe wrote: ↑26 Aug 2021, 16:48![]()
- Discorz
- VIP Member
Whats going on here? Different batches?
Can you please name the monitor you have, Acer Nitro or Aopen FireLegend? And can you check the firmware version?
Note that VRB/TVR needs to be disabled.
Inco^
Mine is acer XV252Q Fbmiiprx.
About firmware version, only information in OSD I got is Series Number: MMTQDEE0011100F4A44200
AG251FZ >> 240Hz TN
AG251FZ >> 240Hz TN
