CortexFPS
Post
by CortexFPS » 06 Sep 2021, 11:42
Discorz wrote: ↑02 Sep 2021, 06:53
CortexFPS wrote: ↑29 Aug 2021, 09:16
Hi guys, I have a problem with the monitor, I have the Acer Nitro version, when the monitor is overclocked at 390hz, if I am playing any game and I push alt-tab going for example on google chrome, the monitor screen starts to blinking continuously, so that I don't go back to the game.
Does anyone else have the same problem as me? and if so, how did it solve?
Thanks
Not sure but it might be related to freesync and fullscreen/borderless/windowed game. Play around with that.
Does it do the same when its not overclocked?
Try better cable? -
https://youtu.be/bPn5avXjSoY
this guy on youtube has my problem but in a slightly different way, always with overclock on, in game I have no problems, but if I keep the game in the background and open google for example, google starts to see itself like this.
The problem only occurs at 390hz, I have a VESA certified display port cable and it supports up to 8K 60hz
https://www.youtube.com/watch?v=bPn5avXjSoY
In use: XG27AQNGV | 272URX | XG2431
Used before: PG27AQDP | 27GR95QE-B | PG248QP | XL2566K | XL2546K/S | XV252QF | AW2521H | VG259QM | PG279QM | AW2721D
amezibra
Post
by amezibra » 06 Sep 2021, 13:48
CortexFPS wrote: ↑06 Sep 2021, 11:42
this guy literraly wrote this in the comment section :
Code: Select all
this problem has been solved by replacing the original cable with a Lindy dp.14 cable, no more flashing @390hz
SirensOW
Post
by SirensOW » 07 Sep 2021, 08:29
You're welcome
- 5E26FEF2-F163-4B54-9B92-81EDA273DB65.png (1.04 MiB) Viewed 10568 times
Discorz
- VIP Member
Post
by Discorz » 07 Sep 2021, 10:42
Optimum Tech review of XV252QF is out! -
https://youtu.be/GrVWF91zCGU
Thank you for doing it!
UFO Speed: ∼1080pps (1170pps @390Hz, 1080pps @360Hz,1200pps? @240Hz)
Dark cyan track - wider ghosting trails, less overshoot.
UFO Speed: ∼ 960, 1080, 1920pps (780pps, 1170pps, 1950pps)
Discorz on 15 Sep 2021, 04:18, edited 3 times in total.
gbmaster
Post
by gbmaster » 08 Sep 2021, 08:08
wow, it looks so blurry in comparison to the 240hz with ulmb
I think i'll just wait until the next generation of monitors if 390hz isn't even making a difference!
Zace
Post
by Zace » 08 Sep 2021, 13:10
Latency reasons? What reason?
Discorz
- VIP Member
Post
by Discorz » 08 Sep 2021, 13:56
And this is how XG2431 looks. It can even be improved further. Amazing!
XG2431 PureXP 240Hz non-QFT ,
source
middle screen, middle cyan track
lizardpeter
Post
by lizardpeter » 08 Sep 2021, 14:38
BTRY B 529th FA BN wrote: ↑08 Sep 2021, 13:51
Zace wrote: ↑08 Sep 2021, 13:10
The Firestorm was $399 now it's back to $449, so price and latency.
What is the issue with latency? Am I missing something? It seems to have less latency than the previous lowest latency monitor (PG259QN).
lizardpeter on 08 Sep 2021, 15:19, edited 1 time in total.
OP1 8K V2 | Field75 HE
