Is your transformer working as it should? 0 inputlag? or are there still traces of lag?dervu wrote: ↑14 Dec 2022, 17:43There is something that toroidal transformers don't like, DC component. If you can hear it buzzing, then it means there is some DC. Then performance drops. I do not know if performance drop is high enough to cause any issues, maybe if someone bought low VA and is borderline enough?
Another thing worth considering is if nothing is going through ground cable, since it is the only cable having direct connection in balanced toroidal transformer. Myself I decided to work with ungrounded, if it fails at least I will know whatever was causing it, went through live or neutral that completely goes through transformer.
This fixes the electrical input lag
Sqnax17
Re: This fixes the electrical input lag
- cybepine
DO NOT remove ground. I am warning you. Major safety hazard!. And no one should buy "technical" transformers.dervu wrote: ↑14 Dec 2022, 17:43There is something that toroidal transformers don't like, DC component. If you can hear it buzzing, then it means there is some DC. Then performance drops. I do not know if performance drop is high enough to cause any issues, maybe if someone bought low VA and is borderline enough?
I repeat do not do this!
Floating grounds can be dangerous if they are caused by failure to properly ground equipment that was designed to require grounding, because the chassis can be at a very different potential from that of any nearby organisms, who then get an electric shock upon touching it. Live chassis TVs, where the set's ground is derived by rectifying live mains, were common until the 1990s.
Exposed live grounds are dangerous. They are live, and can electrocute end users if touched. Headphone sockets fitted by end users to live chassis TVs are especially dangerous, as not only are they often live, but any electrical shock will pass through the user’s head. Sets that have both a headphone socket and a live chassis use an audio isolation transformer to make the arrangement safe.
https://en.wikipedia.org/wiki/Floating_ground
Sqnax17
you said you have a theroidal isolation transformer, did you test it? did you solve the problem with inputag?cybepine wrote: ↑15 Dec 2022, 02:48DO NOT remove ground. I am warning you. Major safety hazard!. And no one should buy "technical" transformers.dervu wrote: ↑14 Dec 2022, 17:43There is something that toroidal transformers don't like, DC component. If you can hear it buzzing, then it means there is some DC. Then performance drops. I do not know if performance drop is high enough to cause any issues, maybe if someone bought low VA and is borderline enough?
akylen
So is it still ok with the transformer after 5 days?
Sqnax17
- dervu
Because it is pointless. Everyone with some experience with this issue will tell you it can take some time to tell if something works.
5 days is nothing. It is fixed for me 6th day btw. You need weeks/couple of months to rule out things.
For instance, we have balanced transformer, it works and then stops working, but the thing causing this issue is temporarily off, so you still think it is helping, but you don't even know why.
texre
It works just like a battery if you leave it alone and let the bad energy out it works good again.
Astro
texre
Once you play with it, then playing with your electricity it pisses you off even more lol. I’m literally just going to have to move I feel like that’s the only solution long term. Unless you have a massive solar system that can run all day long
delve
get a double conversion online ups with pure sine and charge your batteries / power station with it.
