Why are there no other 360hz TN panels?
kyube
Re: Why are there no other 360hz TN panels?
Post by kyube » 02 Mar 2025, 09:11
NSR333 wrote:
02 Mar 2025, 08:01
Does anyone have any recommendations for a 24.5” 360HZ TN panel that isn’t the Zowie? Ideally looking to spend max £400. I play counter strike at a high competitive level so need the best monitor.
If the Zowie XL2566K really is the best I will save for it, but I just need some opinions from people who know more than me before I spend £600 on a monitor. Thanks in advance!
There are no >360hz TN displays which aren't made by Zowie as of the time of writing.
The XL2566K is a bad purchase as well, due to the added processing delay over other implementations.
Consider the XL2566X+ instead, as it sports the new E-TN panels which have better G2G response times over the old (XL2566K) panel.
NSR333
Post by NSR333 » 04 Mar 2025, 06:19
Really appreciate the reply and the heads up on the xl2566+. Is there any other 360HZ monitors you’d recommend for CS2 that aren’t Zowie?
I really don’t want to spend £550 on a monitor but if I have to I will.
If you have any good sources of info that you could link it would be very useful.
TIA!
