Re: netsh int tcp set global autotuninglevel=disable
Posted: 06 Feb 2025, 06:15
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
Could you provide the registry file you set as CTCP?JimCarry wrote: ↑28 Jan 2025, 08:25I dont really understand you,but if you want to make ctcp and its not working via cmd / powershell command and you are on win 10 you need reg file executed by power run,i try all cmd powershell command it cant be changed to ctcp,the moment i executed the reg file and restart pc, its ctcp as you see in the screen i provide above.
of course big man.as i said i try every single way of chaning,bcdedit commands ,powershell,going to regedit by hand,nothing works except making this on reg file and executing it via powerrun.Syykfk wrote: ↑30 Mar 2025, 05:37Could you provide the registry file you set as CTCP?JimCarry wrote: ↑28 Jan 2025, 08:25I dont really understand you,but if you want to make ctcp and its not working via cmd / powershell command and you are on win 10 you need reg file executed by power run,i try all cmd powershell command it cant be changed to ctcp,the moment i executed the reg file and restart pc, its ctcp as you see in the screen i provide above.
