Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Inputlagger91
Re: Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
In short, I didn't notice the difference, the sight is still not controlled. I bought it on Avito, I live in Moscow, this is the answer to my compatriot.
- kriegsnake
Let me know when you’re done testing.Inputlagger91 wrote: ↑30 Mar 2025, 06:31Good afternoon, everyone, I'm from Russla, I use a translator. Yesterday I came across this post and was very interested in this story, today I bought an hdmi optic cable and at the moment I'm going home and I'm going to test it. I'll write my impressions later.
pervysage19
Was there anything else connected to your monitor besides the optical HDMI cable?Inputlagger91 wrote: ↑30 Mar 2025, 14:23In short, I didn't notice the difference, the sight is still not controlled. I bought it on Avito, I live in Moscow, this is the answer to my compatriot.
ablemor
pervysage19, still fixed?
Inputlagger91
The power supply and this hdmi cable, even the drivers on the video card were updated, removing the old ones through the DDU program before that. There is no difference, the sight is not obedient
pervysage19
That's unfortunate. Seems that your issue may be coming from somewhere else then.Inputlagger91 wrote: ↑30 Mar 2025, 16:23The power supply and this hdmi cable, even the drivers on the video card were updated, removing the old ones through the DDU program before that. There is no difference, the sight is not obedient
These are kind of a shot in the dark but they are things that are easy to try and easy to reverse if they don't do anything:
1. Go into Windows Services (can be found by going into start menu and typing Services or using Run to launch "services.msc" or in the Task Manager as well under the Services tab) and look for the following 2 services:
- Remote Access Connection Manager (rasman)
- Secure Socket Tunneling Protocol Service (SstpSvc)
Stop the services and disable them (remember what the default setting was in case you want to reverse this afterwards, mine were 'Manual' by default).
Reason being is that for whatever reason, I found that after turning on the PC... usually these services are off in the beginning. But soon after, about 5-10 minutes of the PC being on, the services automatically turn on and aim feel goes a bit wonky which is how I noticed these services being a culprit in that.
See if problem still exists.
2. Enable a hidden setting called USB 3 Link Power Management in Power Options and then turn it off. You won't be able to find the setting without enabling it first.
Details on how to do this can be found on the following page: https://www.tenforums.com/tutorials/108 ... ndows.html
By default this setting is hidden and set to Moderate power savings (at least it was on my PC)
Inputlagger91
I'll try to do it tonight after work, thanks for the advice, and then I'll write back
babooz99
It does feel smoother for me less input lag but maybe its placebo
buzzik
Does this fix hit reg issues in CS2 and dying behind walls all the time?
Sari
https://www.amazon.com/DisplayPort-Disp ... B0CPJ9VYF1
Is the cable u bought gold plated or silver plated? @pervysage19
