thanks.blurryboba wrote: ↑09 May 2025, 00:24Yes its the model from page 1. AT-UH002BJimCarry wrote: ↑08 May 2025, 18:18- So your driver version is from 2024,but your driver is from 2016(your screen is on Russlan but i think still its right)thats very strange mine is from 2015 on both.blurryboba wrote: ↑08 May 2025, 15:10The driver version in the screenshot
I can't give a link because I bought an adapter from a girl I don't know, not from a store.
Another 3 games with this adapter
Game feels so good
-I did not see your advanced options?
-what do you mean you cant link,its not from a store,just look at the device,see what is the model,brand etc, and paste the model here?,is it the one from your post on page 1 ?
[$10 USB Ethernet!] now i can enjoy faceit cs2 after more than 5 years of suffering
JimCarry
Re: [$10 USB Ethernet!] now i can enjoy faceit cs2 after more than 5 years of suffering
JimCarry
Thanks but i throw away the package,is there is other way to check what version is mine,in the site selling the one that i bought it says it is using "chipset:RTL8153".blurryboba wrote: ↑09 May 2025, 08:55Misha1337 wrote: ↑09 May 2025, 07:08You might ordered an older revision/version because there is around 5 versions of the UE300 that are all utilizing the same chipset but different driver versionsJimCarry wrote: ↑08 May 2025, 12:19can you give link what did you order and what is your net advanced option and what is your new nic driver date and version ?blurryboba wrote: ↑08 May 2025, 01:32The product arrived, I tried it yesterday.
I can definitely say that this ethernet adapter changes something in the game. I've played 5 games on faceit and I can definitely say that it registers hits much better now. The game feels 100% different.
I have 5 games in a row with kdr>1 with this bad boy. 2500 elo
Also don't buy the UE300C version 2 because it's not using the realtek RTL 8153 it's using a different chipset ASIX chip only version 1 using the realtek
Date of manufacture 08.2022
milojr21
download the latest drivers off tp link and it gives you more options in advanced settingsJimCarry wrote: ↑07 May 2025, 02:23Hi so today i buy this bad boy https://www.tp-link.com/nordic/home-net ... ory/ue300/,first i uninstall my realtek latest nic driver 2025,then i go to my bios and disable my realtek 2.5,and then i install the new one.so the moment i plug it wanted to see what option it has and what is the driver,i plug my usb nic into the port i color with red,my 8k mouse into the port i color with blue,and keyboard into the port i color green,i played deathmatch, and i must say there is difference,my question is should update driver to new one?and if yes then from where?,also why there is no so many options like transmit receive,rss,etc ?
JimCarry
did you have the same thing is it better with the newest drivers?,also i find some options in the registry that doest not show in the advanced tabmilojr21 wrote: ↑09 May 2025, 19:43download the latest drivers off tp link and it gives you more options in advanced settingsJimCarry wrote: ↑07 May 2025, 02:23Hi so today i buy this bad boy https://www.tp-link.com/nordic/home-net ... ory/ue300/,first i uninstall my realtek latest nic driver 2025,then i go to my bios and disable my realtek 2.5,and then i install the new one.so the moment i plug it wanted to see what option it has and what is the driver,i plug my usb nic into the port i color with red,my 8k mouse into the port i color with blue,and keyboard into the port i color green,i played deathmatch, and i must say there is difference,my question is should update driver to new one?and if yes then from where?,also why there is no so many options like transmit receive,rss,etc ?
milojr21
idk if its better but its nice having the extra options availableJimCarry wrote: ↑09 May 2025, 20:10did you have the same thing is it better with the newest drivers?,also i find some options in the registry that doest not show in the advanced tabmilojr21 wrote: ↑09 May 2025, 19:43download the latest drivers off tp link and it gives you more options in advanced settingsJimCarry wrote: ↑07 May 2025, 02:23Hi so today i buy this bad boy https://www.tp-link.com/nordic/home-net ... ory/ue300/,first i uninstall my realtek latest nic driver 2025,then i go to my bios and disable my realtek 2.5,and then i install the new one.so the moment i plug it wanted to see what option it has and what is the driver,i plug my usb nic into the port i color with red,my 8k mouse into the port i color with blue,and keyboard into the port i color green,i played deathmatch, and i must say there is difference,my question is should update driver to new one?and if yes then from where?,also why there is no so many options like transmit receive,rss,etc ?
JimCarry
why what the benefit of them? also i take a picture of my device,because the package is in the garbage,and it says its version 5, so i will download the version 5 driver from 2023 and see if its better then stock one.milojr21 wrote: ↑09 May 2025, 21:02idk if its better but its nice having the extra options availableJimCarry wrote: ↑09 May 2025, 20:10did you have the same thing is it better with the newest drivers?,also i find some options in the registry that doest not show in the advanced tabmilojr21 wrote: ↑09 May 2025, 19:43download the latest drivers off tp link and it gives you more options in advanced settingsJimCarry wrote: ↑07 May 2025, 02:23Hi so today i buy this bad boy https://www.tp-link.com/nordic/home-net ... ory/ue300/,first i uninstall my realtek latest nic driver 2025,then i go to my bios and disable my realtek 2.5,and then i install the new one.so the moment i plug it wanted to see what option it has and what is the driver,i plug my usb nic into the port i color with red,my 8k mouse into the port i color with blue,and keyboard into the port i color green,i played deathmatch, and i must say there is difference,my question is should update driver to new one?and if yes then from where?,also why there is no so many options like transmit receive,rss,etc ?
- this.GIF (163.58 KiB) Viewed 2712 times
JimCarry
so i install the latest drivers from the tp site,and now the driver is from 2015 to 2023,and now there is more options,but can someone explain this options this is the first time i see them ever ?
- wtf.GIF (480.28 KiB) Viewed 2703 times
JimCarry
i just want to say straight away when i update to the latest drivers,my mouse becomes heavy and its way worse,i will go back to the default stock from 2015 its way better,i read in this forum,someone here says that exactly what happened to me,when i plug the device the stock driver is 2015 and its running ok,my mouse is light and i can peek,but there is 6 options in advanced options,but when you update to the latest version it will have more options,but its worse in my opinion.
- fgind it.GIF (120.82 KiB) Viewed 2683 times
blurryboba
After 17 games, my game feels terrible again. I cant make a 100% kills again.
I tried reinstalling the driver, but it didn't help.
The statistics speak for themselves
- Снимок экрана 2025-05-12 155909.png (319.36 KiB) Viewed 2550 times
- Снимок экрана 2025-05-12 155723.png (425.07 KiB) Viewed 2550 times
JimCarry
so for you it use to works couple days ago,now its back to old ? so its placebo for you ? internal or external nic ?blurryboba wrote: ↑12 May 2025, 07:59After 17 games, my game feels terrible again. I cant make a 100% kills again.
