[$10 USB Ethernet!] now i can enjoy faceit cs2 after more than 5 years of suffering
shell
Post by shell » 25 Apr 2025, 08:09
Hey everyone,
backstory: I've been playing counter strike: go since 2016. Playing at internet cafes always felt way smoother, responsive than at home. Over the years, I was constantly upgrading my home pc with new/used components, sometimes even buying full used rigs from people or small builder services. I’ve tried all kinds of setups. The game always felt choppy, and things got worse around the 2018-2019 after faceit ac update when windows 7 support ended. That’s when you had to enable Secure Boot in BIOS and switch to newer windows versions. Since then, I’ve gone through pretty much every Windows 8 and 10 build you can imagine — stock, LTSC, LTSB, Revios, Enterprise. I followed RAM timing guides, BIOS tweaks, registry edits, diffent GPU driver install techniques, bios firmware… I went absolutely down the rabbit hole........................ :ugeek:
I even thought the issue might be electricity or my crappy gpon isp.
since I work in web dev, I got curious: how do large data centers or trading firms set up their hardware for low latency? These guys have conferences where they analyze 10-20 lines of high-performance code for hours, choose the most latency-optimized Linux kernel configs, and fine-tune CPU behavior.
I spent hours on forums looking into how they deal with dirty/harmonics power filtering, but all I really found was a general recommendation to ground your hardware. Nothing like "THIS IS CRUCIAL" or anything — just casual advice.
so here’s the biggest takeaway I got from all of this: power delivery issues(emi, rfi, hormonics) is not the bottleneck in ultra-low-latency systems. If EMI or electrical noise really made that much of a difference, those guys would be writing books on which toroidal isolation transformer gives you the lowest latency for your next custom kernel build.
eventually, I admitted to myself — I don’t want to dig into this crap anymore. after all those years tweaking os settings, overclocking, bios versions, and getting nowhere… I just gave up on chasing phantoms. I came to the conclusion that the problem is in hardware compatibility
so I decided to build a completely new pc strictly following manufacturer guidelines. picked motherboard, chose ram from the supported list, bought a high-quality PSU, and got a physical retail copy of Windows 11. It was super important for me that every single component was brand new and factory-sealed, so I ordered everything from the us and had it shipped to the CIS.
My build:
AMD Ryzen 5 7600 (Box version, NOT tray!)
Arctic Freezer 36
XPG Lancer Blade 32 GB (2x16GB) DDR5 CL30, model: AX5U6000C3016G-DTLABBK
Samsung 990 Pro 1TB PCIe 4.0
Super Flower Leadex III ATX 3.1 1000W
ASUS TUF GAMING B650-PLUS WIFI
I also paid attention to details I never cared about before — stuff that was in the manuals:
installed RAM in the correct slots (before I just inserted sticks through 1 to make the dual channel work)
the board has both 1xpcie 4.0 and 4xpcie 5.0 slots. at first, i wanted to use the pcie 5.0 one because it's in the spotlight location, but after researching, I went with the pcie 4.0 slot for better compatibility, and it’s next to the chipset. The 5.0 slot is right under the cpu, and users reported overheating (up to +20°C at idle) from cpu heat bleeding onto the ssd.
os install process: before installing Windows, I changed bios to secure boot and made sure ftpm was enabled (needed for faceit ac). i did a standard win 11 home install, choosing default options wherever possible. Important: set your correct region so the time zone syncs automatically. after i let windows install all the drivers itself, then installed all the latest updates via windows update.
then i installed AI Suite 3 (from ASUS) — gui for tuning/overclocking — and just used the automatic oc tuning options it provided.
next, i installed Steam, downloaded CS2, and wiped all my CS2 saves from the Steam Cloud.
Order matters.
Why?
if i install a “clean” GPU driver manually without internet on first boot? → desync
if i pick wrong time zone → system timer breaks -> desync
if i reinstall windows and forgot to clear tpm key? -> desync
if i i dsable xbox overlay? -> desync. It’s like a blockchain: mess up one step, and the whole chain breaks, one wrong step where you provided the os with incorrect data, other dependencies took data from its api, the os is not synchronized
result:
I got the best smoothness, input response, and mouse movement I've ever felt. mouse sensitivity feels static — not dynamic and floaty. rapid trigger keyboard feels insanely responsive, after installing faceit ac, the game stayed smooth (before this, enabling faceit ac on my old PC would completely kill input delay — made CS2 feel like I was using a $10 Genius keyboard)
important note:
all of this improved only the client-side experience, I still play faceit with 50ms ping and definitely feel that players with 5–20ms have an adventage when peeking — or when I peek them. But think this is a low netcode thing.
$10 usb-to-ethernet adapter fixed a problem I’ve had for years. i used motherboards with different NICs, tried multiple routers, QOS settings, Cat5/Cat6 SFTP cables, upd tweaks, wi-fi, 4g… nothing fixed ferrari peeks from enemies it — until this usb-ethernet cord.
my exact model: DEXP AT-UH002B with a Realtek 8153 chip.
Re: now i can enjoy faceit cs2 after more than 5 years of suffering
Post by Chief Blur Buster » 25 Apr 2025, 14:14
shell wrote: ↑
25 Apr 2025, 08:09
It's amazing how sometimes motherboard onboard-Ethernet is so crappy, that a $10 Ethernet adaptor solves a lot of problems.
(Same for onboard audio too; where a $10 USB DAC improves framerate + latency)
(Same for $10 PCIe USB cards to replace crappy on-board motherboard USB ports)
So many weak links to worry about. Sometimes (not always) there are cheap solutions. Sometimes it's not the Ethernet but USB congestion (too many USB devices that are actually also sharing motherboard chipset resources and/or same jittery x1 PCIe lane with WiFi & Bluetooth). Or it is Microsoft audio drivers versus vendor audio drivers (sometimes one of the 2 drivers is laggy).
Woe is those unlucky people who needed two or three adaptors (e.g. bypass the whole crappy chipset and use PCIe and/or externalize the Ethernet/Audio/USB) -- imagine all the troubleshooting they had to do. Easier to troubleshoot by motherboard replacement sometimes.
No wonder the reputable PC optimizers (who know their bleep) earn a good dime now.
(...be noted, some advertising as being optimizers are not worth more than snake oil or hackers/phishers, while others are really kickass good who is worth every penny...hard to figure out who is good...so do lots of homework, as much time in homework as it takes as your first optimization attempts took in time before you gave up...caveat emptor though!...)
JimCarry
Re: [$10 USB Ethernet!] now i can enjoy faceit cs2 after more than 5 years of suffering
Post by JimCarry » 25 Apr 2025, 22:16
shell wrote: ↑
25 Apr 2025, 08:09
Hey everyone,
My build:
Arctic Freezer 36
Order matters.
Why?
result:
important note:
i think you are number 4, person that says that,the nic you say that fixes everything "exact model: DEXP AT-UH002B with a Realtek 8153 chip." when i type it google,there is only Russlan sites selling it,is there any site that is not on Russlan? also can i ask you why order all of your parts from usa,but not the nic ?
Misha1337
Post by Misha1337 » 26 Apr 2025, 19:04
JimCarry wrote: ↑
25 Apr 2025, 22:16
shell wrote: ↑
25 Apr 2025, 08:09
Hey everyone,
My build:
Arctic Freezer 36
Order matters.
Why?
result:
important note:
I found a device TP-Link UE300C (type C) using the same chipset RTL8153 and am curious to try it do you think it will be the same as the one using the normal USB A not the type C ?
DanGamesTwitch
Post by DanGamesTwitch » 26 Apr 2025, 19:18
Brother, I understand you are from Russla, I can also tell you, do you have fiber optic internet? or twisted pair LAN cable?
shell
Post by shell » 27 Apr 2025, 00:43
JimCarry wrote: ↑
25 Apr 2025, 22:16
shell wrote: ↑
25 Apr 2025, 08:09
Hey everyone,
My build:
Arctic Freezer 36
Order matters.
Why?
result:
important note:
I found information about usb-ethernet on this forum, I wanted to get a tp-link tl-ue300, but they were out of stock in my city, so I googled what chip is used there, and got one with same chip.
I don't trust nic, from them from you can get a showcase part or returned one. there are no official resellers in my city, local stores have a small assortment, also highly overpriced, shipping from the us will come out much cheaper
shell
Post by shell » 27 Apr 2025, 01:08
DanGamesTwitch wrote: ↑
26 Apr 2025, 19:18
fiber from isp to splicebox, cable has no marks
fiber -> splicebox -> mediaconverter -> utp cat5a to keenetic hopper -> utp cat5a to ethernet usb -> pc usb
photo_2025-04-27 11.51.14.jpeg (103.87 KiB) Viewed 9554 times
TN_fun
Post by TN_fun » 27 Apr 2025, 10:12
Hi guys. But I don't get it. Okay, this guy bought all new components in the US, bought a Windows 11 license.
But why did he buy a USB Ethernet adapter? So his new PC is still out desync? If so, a new adapter won't solve anything, it's temporary anyway.
blurryboba
Post by blurryboba » 01 May 2025, 03:42
I ordered it, I'll check it tomorrow.
JimCarry
Post by JimCarry » 01 May 2025, 17:12
blurryboba wrote: ↑
01 May 2025, 03:42
wich one ?
