No FPS gaming possible
LaggyTyp
Re: No FPS gaming possible
Post by LaggyTyp » 22 Aug 2025, 13:24
Friends... I've literally tried everything.
Here's a short list:
1.) Switched from DOCSIS internet (1GB / Vodafone) to VDSL internet (250 Mbps / Telekom) = ping dropped from ~12ms to 5ms, but gaming was still terrible
2.) Bought the Asus DSL-AX82U = Still terrible
3.) Tried Windows 10, Windows 10 ReviOS, Windows 11, and Windows 11 ReviOS = Still terrible
4.) Tried every conceivable tweak = Still terrible (if it was good once, it was still terrible without tweaks)
5.) Switched back to DOCSIS internet (1GB / Vodafone) = Still terrible
6.) AMD 7800X3D + Asus B650 + DDR5 = Still terrible
7.) AMD 9800X3D + Asus B650 + DDR5 = Still terrible
8.) Stock BIOS = Still terrible
9.) BIOS OC = Still terrible
10.) Smartphone as a router (USB) = From good to terrible
11.) Asus router connected to Fritzbox = Still terrible
12.) Router restart = Still terrible
13.) Disable Wi-Fi = Still terrible
14.) 3x FritzBox 6690 Cable = Still terrible
15.) 1x FritzBox 6670 Cable = Wait and see (but I think terrible)
16.) NordVPN = Terrible
17.) Exit lag = Sometimes good, sometimes terrible (if good = good without)
My problem:
1.) VDSL line belongs to Telekom. No matter the provider = Always Telekom infrastructure (terrible)
2.) DOCSIS line belongs to Vodafone. No matter the provider = Always Vodafone infrastructure (terrible)
3.) No third line available from other providers
4.) 4G/5G is always overloaded, according to people here
5.) Rented apartment
I don't need snake oil. I need a solution.
dermodemon
Post by dermodemon » 22 Aug 2025, 13:45
guys what's default windows 11 timer settings in bcdedit /enum?
donger
Post by donger » 22 Aug 2025, 13:46
Test 4G and 5G on your own using a proper router preferably with external antenna, not your phone, if it's a rented flat then just move out. No other solution is possible.
LaggyTyp
Post by LaggyTyp » 22 Aug 2025, 15:50
I'm already looking for a suitable plan.
5G + unlimited data + no contract term + router incl.
LaggyTyp
Post by LaggyTyp » 22 Aug 2025, 18:13
1&1
Homespot
500 Mbps / 50 Mbps
FritzBox 5G Router
Not available here at the "Farm" (Düsseldorf / state capital).
themagic
Post by themagic » 23 Aug 2025, 02:20
4g or 5g dont gonna help...
I have here o2 with router and 4g but no difference at all and still bad everything...
I tried many things already with mobile Internet and still no solution to my problems...
the ping is very good and stable with this but experience is same like with DSL and fritzbox...
also bad and exact same...no improvement
LaggyTyp
Post by LaggyTyp » 23 Aug 2025, 02:38
A funny thing happened yesterday.
It was running terribly again. Then I changed something in the system, and suddenly it was running so well. It was running perfectly. I wanted to wait a bit longer before telling you. After 9 p.m., it slowly got worse and worse until it was terrible again. It wasn't running well because of my changes. It was a coincidence. I was just lucky that the internet wasn't under much load for once.
It seems like the load is simply too high here. Too many people. Maybe the system starts bundling packets at a certain load?
New Fritzbox (since yesterday) + better results + same terrible experience
Screenshot 2025-08-23 at 09-33-25 FRITZ!Box 6670 Cable.png (430.81 KiB) Viewed 3544 times
LaggyTyp
Post by LaggyTyp » 23 Aug 2025, 03:50
I still believe that a problem with the ISP can be clearly identified and measured.
I can't make anything visible/measurable here. YES, DAMN IT, it feels like an ISP problem, but why can't I see it? Can't measure it? Can't prove it? WTF?
themagic
Post by themagic » 23 Aug 2025, 03:58
Because it is not an ISP issue really and has nothing to do with that what you exprience and feel and see...
Soon we gonna know what rly the issue is...
Kipperii
Post by Kipperii » 23 Aug 2025, 03:59
ChristophSmaul1337 wrote:
22 Aug 2025, 11:51
donger wrote:
22 Aug 2025, 10:39
100% of his problems are ISP related
I've been working with network related things for quite a while, and I know a bit about how this stuff works, all the way down to the "Layer 1" level. However, I'm always happy to learn new things. I am genuinely curious about what you saw in OP's description, pictures or other statements which tells you with 100% confidence that his ISP must be at fault. From what I've read and seen here, I wouldn't come to that conclusion, but I might be lacking critical information. You seem very confident, to the point where you call others a
donger wrote:
22 Aug 2025, 10:39
SCHIZO
I'm open for new insights that might have flown underneath my radar for the 20 years or so that I've been dealing with computers and networks. I know for you this is absolutely obvious and you're very likely a 160+ IQ genius, but us mere mortals aren't as knowledgeable as you, so please take 5 minutes out of your highly valued time to explain to us peasants what's making you so confident. Thanks a lot.
Ignore him, he's just destroying this thread
