Acer 390Hz monitor - XV252QF
ms.potatoe
Post by ms.potatoe » 18 Sep 2021, 04:52
Flickering at 390Hz ( outside fullscreen app ) its a problem with freesync range. Last AMD driver without this issue was 21.5.2. I normally disable freesync in radeon software when i'm not playing games for this reason.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 18 Sep 2021, 08:33
Badnick92
Post by Badnick92 » 18 Sep 2021, 10:14
Hi guys. I am Nick. I am from France. I just bought this monitor Acer XV252QF from Acer France website and I got two issues :
- 1 st one you are aware is the VRB back to OFF after each PC restart
- 2nd issue is Monitor randomly goes black for a second when I am on DP (390hz). (when, gaming or browsing on web etc..). If I switch to HDMI (240hz) it is fine btw. All my drivers are up to date so I guess a PSU issue maybe. Tell me if you got the same issue. I will try to reach Acer France to get their opinion and I will try to find another DP cable to see if it resolves the issue.
- 3rd issue : I got flickering sometimeswhen browsing on google chrome and the monitor is laggy aswell.
Maybe the monitor PSU is faulty.
Asus GA15DK (R7 5800X ; RTX3070 ; 16GB ; 700W PSU) - Acer XV252QF OC 390HZ Normal OD Extreme VRB
bhoff
Post by bhoff » 18 Sep 2021, 14:08
I had the issue with flickering at first, I found I had to disable FreeSync on my 2nd monitor and only have it enabled for the 390hz monitor. Once I only had FreeSync enabled for the 390hz monitor the flickering completely stopped.
lablaka
Post by lablaka » 18 Sep 2021, 15:16
The thing is that you guys are using an AMD GPU and FreeSync, while I'm using an Nvidia GPU with all syncing technologies on all monitors turned off and it's still going crazy when using 390 Hz.
lizardpeter
Post by lizardpeter » 18 Sep 2021, 19:37
lablaka wrote:
18 Sep 2021, 15:16
I really hope I do not have this problem when mine arrives in a week. I have an RTX 2080 Ti and do not use GSYNC. Does anyone know if this monitor's firmware can even be updated by us? I know most of my previous monitors couldn't be.
i9 9900k | RTX 2080 Ti | 32 GB 4x8GB B-Die 3600 MT/s CL16 | XV252QF 390 Hz 1080p | AW2518H 240 Hz 1080p | PG279Q 144 Hz 1440p
Razer Viper 8K | Artisan Zero Mid XL | Apex Pro TKL | 1 gbps FiOS (Fiber)
valgar
Post by valgar » 18 Sep 2021, 19:52
lablaka wrote:
18 Sep 2021, 15:16
Yes, as you say it can't be FreeSync dependant. I don't have a second monitor and I have a 5700 XT, I keep FreeSync disabled anyway both from the OSD and radeon software.
Evis
Post by Evis » 19 Sep 2021, 03:25
i dont use gsync / freesync and i have no problem on 390 hz with 5 year old gpu.. fix your cables i guess. also multiple monitor setup ofc.
Notty_PT
Post by Notty_PT » 19 Sep 2021, 10:54
No problems here aswell, using AMD gpu + cpu, no adrenaline software, only gpu driver.
390hz no Freesync
But I dont think this is a great monitor anyway. Input lag increases ar 390hz compared to 360hz, it is blurry (even tho, less than the other models)
I am still in the 30 day return day, and I think I Will return it
Zace
Post by Zace » 19 Sep 2021, 12:44
Notty_PT wrote:
19 Sep 2021, 10:54
390hz no Freesync
Really? So 390hz have more input lag than at 360hz? That can’t be right…
