Page 35 of 35
Re: Asus XG27AQDMG Discussion
Posted: 30 Jul 2026, 11:59
by RealNC
Rewire wrote: ā30 Jul 2026, 11:56
As for the User mode thing, I tried it and compared to racing mode, it kinda seems like Racing mode feels more blue/cold-ish compared to User mode with those settings, and I don't really mind this one it looks alright.
Yes, if you reduce red, the image gets "colder."
Anyway, the way I play SDR games is in HDR mode and use Special K to map SDR to HDR with correct gamma.
Posted: 12 Aug 2026, 13:06
by Rewire
Can we make a topic on asus forums to get TrueBlack 400 HDR mode on the OSD? It seems like majority of the monitors that came after this one has that feature
Posted: 12 Aug 2026, 23:01
by RealNC
Rewire wrote: ā12 Aug 2026, 13:06
This panel is natively TB400. It doesn't need a special mode for it.
The reason the latest gen panels have a special TB400 mode is because latest gen WOLED has removed the white subpixel, and thus they behave more similar to QD-OLED. They cannot reach peak brightness while maintaining TB400 certification. The older gen WOLEDs can, so no special mode needed.
Edit:
Well, unless you use the weird Asus hack of enabling "adjustable HDR" and raise brightness from 90 to 100. I'm not sure the monitor is still TB400 then. Just don't enable that hack, as it has the tendency to negatively affect colors anyway.
Posted: 03 Oct 2026, 06:03
by Pointsintostrength
Is 2.0 gamma still closer to 2.2 @ 240hz after the 108 firmware update?
Posted: 03 Oct 2026, 08:24
by RealNC
Pointsintostrength wrote: ā03 Oct 2026, 06:03
I don't think anything changed there. 2.2 is still too dark at 180Hz and 240Hz. At 60Hz definitely use 2.2. At 120Hz... it's a split. There's no 2.1 setting
So use whatever looks better to you.
