Posted: 18 Feb 2026, 17:25
Chief you testing the new Pulsar firmware yet?
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
I have the Acer model, and this behaviour was discussed earlier in the thread. Mine does the same – below 90 Hz it frame-doubles to 180 Hz instead of turning the strobing off.mawi wrote: ↑18 Feb 2026, 05:211) I have seen in some videos that pulsar should turn off once my fps goes below the threshold... either 90 Hz default or 75 Hz. But mine doesnt... I have the display internal FPS count running on top left of the screen and my steam overlay FPS on top right. And when I drop below 90... even when I go down to 40 fps (on Portal RTX that is easily possible), the display fps starts showing triple the Hz. And it is still strobing. I have checked that via phone camera and its strobing all the time.
Which I dont think is good. Actually I do not even want the double Hz, I would rather prefer it to stop strobing because when there is the double Hz mode, you clearly see a double image.
We also see this on the UFO test... with 360 Hz screen res, the 180 Hz UFO is double. each of both is sharp but you can clearly see two of them.
If I run my display at 240 Hz, the 240 fps UFO looks as clear as the 360 fps native UFO in my opinion. 240 is not that far away from 180 but it looks SO much better as its not doubled.
For this reason I would prefer pulsar to really turn off once its below the threshold but I have no idea how to achieve this?!... Why do all testers say its the case on their side?
John from Digital Foundry mentioned that Nvidia have been finding it more challenging that they thought it would be but its coming soon.Chief Blur Buster wrote: ↑18 Feb 2026, 18:04I am still waiting for my updated sample & firmware.
Thank you for bringing the Pulsar discussion back on topic!
Ah ok. And what about the DSC full screen handshake blackouts when using 360 Hz? Does Acer show this behaviour as well? All posts about this I have seen on reddit so far (on pulsar displays but also on 360 Hz DP1.4 OLED screens) are with Asus models.
I don't get this issue with the Acer, never black screens. I use a RTX 5080 with it.
Ah, thanks. Ok you have an RTX50... as far as I read there is no handshake problem with RTX50, only with 30 and 40 series. The display is DP1.4 and the rtx50 series have dp2.1, it seems like the new heads manage the handshakes better even if they only use the 1.4 signal. Also AMD cards are better, but with pulsar they are anyway no option yet.brownvim wrote: ↑19 Feb 2026, 04:37I don't get this issue with the Acer, never black screens. I use a RTX 5080 with it.
I do have a bug where when I start windows it defaults to 240hz sometimes instead of 360hz, i swapped my display port cables around and bought new ones but it comes and goes, no pattern to it. I have to remove the cable and reinsert it to the monitor for 360 to work.
You should be able to try Pulsar in ULMB2 mode to help answer your question, at least I know you can with the Asus. The steps I did were to fully enable Pulsar (enable in monitor, and enable GSync in nvidia control panel), then disable GSync in the nvidia control panel. Kyube posted somewhere earlier about the exact process from the manual.shapaco wrote: ↑18 Feb 2026, 08:15Does it make sense to return the Pulsar and buy a ULMB2-only monitor with the same specifications, which is hopefully cheaper and offers the option to further narrow the strobe pulse width, potentially increasing motion clarity even more? Would such a monitor also use line strobing?
On the other hand, if a future firmware update were to allow a reduction of the strobe pulse width in ULMB2 mode, I might end up regretting returning the monitor...
As of the time of writing:shapaco wrote: ↑18 Feb 2026, 08:15My question:
I'm aware too. I'd rather NVIDIA do the time to get the firmware right.brownvim wrote: ↑18 Feb 2026, 18:19John from Digital Foundry mentioned that Nvidia have been finding it more challenging that they thought it would be but its coming soon.Chief Blur Buster wrote: ↑18 Feb 2026, 18:04I am still waiting for my updated sample & firmware.
source: https://www.youtube.com/watch?v=MnCHHSwa7R4&t=4536s
Indeed!
