Re: I finally found the Reason for my Problem
Posted: 17 Oct 2023, 20:05
so how he could test more than 15 pcs with everything new in >>different countries<< and be so unlucky to get the exactly same issue at the same level? I also confirmed my interference comes from my body, tried more than 20 pcs and 1 one them was actually way better, but not even close to fix too. it was at my friends house, so this is possible to happen even with the problem being our bodyPatrykelele wrote: ↑17 Oct 2023, 16:40I would say you might be the problem, but not at all let me expian. I was on gaming event called PGA. Once every year companies can buy space to show their gear and many of them have place to play if you want. I tested pc it was laggy as hell same if i would play from home same lags. Then i went and test next pc in other building damn it was the best gaming experience ever. I don't know why but it might be something about pc gear and monitor.Palacko wrote: ↑08 Oct 2023, 07:00Hi Guys,
many of you guys will know me from my videos:
https://youtube.com/shorts/PEQYnqav-a4? ... bWsQMzkbkR
As i told before, i am struggeling since 2020 with this problem and the problem followed me whereever i go.
10 different Countries, 15 new Pcs with everything new.
Now i am in Dubai, i play with Account from Gaming Club - 1 Ping to Dubai Servers.
First Hour it was very good i could hit good and then the Problem is starting again, slow movement, slow bullets, prefiring..
I found out that my Body is causing all of this, also people in my House could play good after i move from chair. First its also bad for them, because my inpact to pc/mouse seems huge, and it takes 30-60mins till pc is working fine again.
I never thought that this could be real, but also others reporting about the same.
So it will be unfixable for me, my body has something which is not fitting with gaming anymore. I was ESL #1 in 2007-2010 so i know a lot about Gaming and was like Pro in this time.
