OLED 4K 30" 60 Hz - Dell UP3017Q
spacediver
Re: OLED 4K 30" 60 Hz - Dell UP3017Q
Post by spacediver » 22 Apr 2017, 00:03
I think at a certain point it's a waste, as the persistence of the human visual system is a factor (the human visual system does have it's own form of motion deblurring, but I'm not sure what it's limits are).
thatoneguy
Post by thatoneguy » 22 Apr 2017, 00:12
tbh i think scientists out there have already thought of all these things before
for example i think for holograms to work properly we would need that sort of extremely low persistence
Glide
Post by Glide » 22 Apr 2017, 00:26
Reducing the strobe duration is not going to improve double-images.
If anything it would make them worse since each image will be more distinct.
If you're displaying a 60 FPS source and strobing at 120Hz, the strobes are still going to be 8.33ms apart no matter how long or short the strobe duration is.
thatoneguy
Post by thatoneguy » 22 Apr 2017, 00:36
Glide wrote:Reducing the strobe duration is not going to improve double-images.
Except that's not how physics work when you get past a certain point. At some point when you go way too low an opposite effect appears
It's like how numbers below 0 count upwards(e.g -1, -2, -3, -4). It's a common thing in mathematics and science and is consistent with the laws of the universe.
So, in short when you go way too low that opposite effect starts happening and the double-image effect should disappear entirely because it's way too fast for the human brain to pick up.
Glide
Post by Glide » 22 Apr 2017, 00:46
Reducing the strobe duration does not change the frequency of the strobe.
It's still operating at 120Hz.
And if you increase the frequency high enough that you no longer see the flicker, then it will be equal to a sample and hold display and start blurring the image again.
thatoneguy
Post by thatoneguy » 22 Apr 2017, 19:51
Glide wrote: Reducing the strobe duration does not change the frequency of the strobe.
Sigh...I give up, you clearly don't get physics
Glide
Post by Glide » 22 Apr 2017, 21:08
Perhaps you could back up your claim with evidence instead of saying that I "don't get physics" because it really seems like you're confusing strobe duration with strobe frequency.
i.e. Bringing the strobes closer together until we no longer perceive them as being separate images, rather than reducing how long each strobe lasts.
Falkentyne
Post by Falkentyne » 22 Apr 2017, 21:35
You're completely wrong.
Do you know the difference between persistence and timing?
If you do, why don't you explain it?
Haste
Post by Haste » 22 Apr 2017, 21:54
What the hell did I just read? :shock:
Something tells me this thread will need some clean up.
Monitor: Gigabyte M27Q X
thatoneguy
Post by thatoneguy » 23 Apr 2017, 00:10
Glide wrote: Perhaps you could back up your claim with evidence instead of saying that I "don't get physics" because it really seems like you're confusing strobe duration with strobe frequency.
Ok let me explain it in words you might be able to understand
If you flash the same image twice or more times at a speed which the human brain/eyes cannot detect the double image effect goes away. The reason we see double images when we double strobe is because the persistence is within our viewing/detection threshold.
There, you happy?
