FSO vs. Exclusive Fullscreen
daviddave1
Re: FSO vs. Exclusive Fullscreen
Post by daviddave1 » 24 Apr 2022, 07:01
1000WATT wrote: ↑
24 Apr 2022, 06:53
daviddave1 wrote: ↑
24 Apr 2022, 04:42
I couldn't do it with this method. But this is not the only method.
It is possible that another person will have more luck. ;)
Thank you dude! Fr33thy couldn't do it also ( on Server 2019) but he told me that on the latest Windows Builds FSO is the same now as Exclusive Fullscreen with inputlag. ( he said a mate of him tested it)
| Now: XG27AQNGV
R1sk
Post by R1sk » 25 Apr 2022, 01:47
chenifa wrote: ↑
26 Nov 2020, 09:42
@1000WATT
I restored my Children folder with gamebar and set "Flags" to 211 hex....it still doesn't work unfortunately. Have you managed to get FSE back?
Flags to 11 Hex not 211 Hex who said 211 and why?
eliasballz
Post by eliasballz » 25 Feb 2025, 08:34
jorimt wrote: ↑
25 Nov 2020, 09:35
howiec wrote: ↑
25 Nov 2020, 06:37
Borderless Fullscreen with FSO on Apex Legends leads to minimum additional 1 frame latency.
On this note, just to be clear on my previous comments to everyone here, when I was talking about FSO vs. exclusive fullscreen, I was talking about FSO on + game set to exclusive fullscreen vs. FSO off + game set to exclusive fullscreen only.
- Game set to "borderless/window" + FSO on = borderless/window behavior (retains DWM composition + Fast Sync-like V-SYNC solution)
- Game set to (exclusive) "fullscreen" + FSO on = exclusive fullscreen behavior (with allowance of adaptive DWM for overlays/alt+tab transitions + tearing with in-game or CP V-SYNC off)
I've seen DSI/DSR scaling quirks sometimes occur with the borderless scenario (vs. borderless + FSO off), however (may have been addressed since though, or was game specific; primarily saw this in Sunset Overrdive which only supports borderless).
Anyway, due to DWM, borderless/window does indeed add 1 frame of latency over exclusive fullscreen:
h
For the most responsive experience, borderless/windowed (FSO on or off) must be avoided, and exclusive fullscreen (FSO on or off) must be used instead.
Obviously, exclusive fullscreen isn't always an option though, so borderless/windowed G-SYNC mode is the next best bet, as it appears to bypass DWM in that mode regardless (I will test this again in the latest Windows build for confirmation when/if I receive an LDAT from Nvidia):
Finally, during my original G-SYNC 101 tests, I also tested all combos of Game Mode, Game Bar, and FSO off-record, and found no measurable input lag differences. See:
viewtopic.php?f=5&t=3441&start=10#p26839
For the record, I know my "G-SYNC 101" article only evokes "G-SYNC" when people see that title, but in actuality, it fully covers G-SYNC, double buffer (and to a lesser degree triple buffer) V-SYNC, Fast Sync, V-SYNC OFF (no sync), exclusive fullscreen, borderless/window, and in-game/external FPS limiter scenarios (and across 6 refresh rates).
hey, i saw your post on the actual blur buster website and saw a guy "shadowlord" respond to you saying he a had a problem with marvel rivals. i wouldve responded there, but i cant send pictures of my benchmarks while running the game. i have a ryzen 7 9700x and a 3060 rtx 12gb and my system is obviously gpu bound and my gpu sucks. im playing on a 240 monitor that has gsync. so im stuttering, or tearing, or something. i used to have unstable fps with stock settings, but i got it to a point where i got stable fps and a stable frametime at 120 fps (even got it to be stable at 140 and 180 before. but i undervolted a bunch thinking it was my gpu usage being a problem) im so frustrated and need help. its been about a month of trying to get rid of these stutters and tears. from the bios turning on pbo and global c states (obvi did ram, expo), to nvidia profile inspector, to msi afterburner undervolting, and underclocking and rtss framelimiter. the images show i have gsync on and vsync off. (after reading your post, i will be trying both on also with vrr? if thats what you meant about vrr in your posts on the blur busters website) i notice fps and frametime spikes with some settings, but even getting rid of them with certain settings, i feel stutters and i even teleport in the game (even the practice area). here are my current settings in the pictures (game mode, hags and vrr off, fso not disabled) along with a benchmark of the game running
nvcp settings
nvcp settings
nvcp settings
nvcp settings
image (1).png (83.5 KiB) Viewed 6170 times
msi afterburner settings
image (2).png (51.33 KiB) Viewed 6170 times
eliasballz
Post by eliasballz » 25 Feb 2025, 08:36
sorry, i couldnt add more than 3 images. but here is my benchmark as well
benchmark
benchmark
image (3).png (45.67 KiB) Viewed 6170 times
rtss settings
rtss settings
image (4).png (5.48 KiB) Viewed 6170 times
Post by jorimt » 25 Feb 2025, 22:25
eliasballz wrote: ↑
25 Feb 2025, 08:34
G-SYNC on + V-SYNC off can still tear. 100% tear-free G-SYNC is G-SYNC on + V-SYNC on.
eliasballz wrote: ↑
25 Feb 2025, 08:34
"VRR (Variable Refresh Rate)" is another term for G-SYNC, FreeSync, adaptive sync, etc. They're all the same thing, fundamentally.
eliasballz wrote: ↑
25 Feb 2025, 08:34
G-SYNC can't reduce or prevent system-side frametime spikes.
All it does is dynamically steer the tearline offscreen for framerates within the refresh rate when properly configured. It's not a "smoothing" mechanic or a system performance enhancer. It essentially aims to be V-SYNC on with latency closer to V-SYNC off, and that's about it.
eliasballz wrote: ↑
25 Feb 2025, 08:34
Teleporting would be more server/ISP than system-side; rubber-banding, ping, etc.
Displays: ASUS PG27AQN, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
Post by Slender » 26 Feb 2025, 12:06
I can’t go back to g-sync off / v-sync off, even though when everything works as it should it doesn’t matter.
1000WATT
Post by 1000WATT » 26 Feb 2025, 13:53
jorimt wrote: ↑
25 Nov 2020, 17:33
(good luck getting Microsoft to replicate it and fix it though :roll:)
That said, my commentary in this thread thus far has been entirely based on the presumption that FSO is working as intended in the posed scenarios.
year2020
Somewhere in the Microsoft office.
Olivia: These guys from the blurbusters forum are always unhappy about something. Something needs to be done.
Isabella: Yes, they don't like how wddm works.
Olivia: Aren't we doing everything we can to make FSO mode perform better and be more comfortable than FSE mode?
Isabella: This will require large financial investments and the involvement of highly qualified programmers.
Olivia: There must be another way!! Find another way out!!!
year2024
Isabella: We have done a truly outstanding job and are pleased to introduce WDDM 3.1 to you. https://youtu.be/mUB6YLuJRZk
Isabella: After we broke FSE, no one will argue that FSO is inferior in any way.
Olivia: This is an amazing decision, I'm proud of you.Finally those guys from the blurbusters forum will be happy.
ManWhoSoldTheWorld
Post by ManWhoSoldTheWorld » 26 Feb 2025, 16:11
@1000WATT - Your overlay says «Legacy Flip» in the YouTube clip
Z3CrosS
Post by Z3CrosS » 26 Feb 2025, 16:19
I think that i don't think
Z3CrosS
Post by Z3CrosS » 26 Feb 2025, 16:50
