Offgridding PC on Battery for Under $400 -- Be Your Own Power Company For Cheap -- 12.8V 100AH lithium-iron batteries
ZINZIRIO
Re: Offgridding PC on Battery for Under $400 -- Be Your Own Power Company For Cheap -- 12.8V 100AH lithium-iron batterie
Post by ZINZIRIO » 09 Jun 2025, 23:26
Slender wrote: ↑
09 Jun 2025, 23:25
ZINZIRIO wrote: ↑
09 Jun 2025, 23:22
Slender wrote: ↑
09 Jun 2025, 01:51
ZINZIRIO wrote: ↑
07 Jun 2025, 23:52
In your case, doesnt it always work? In my case, it works perfectly the first time, but everything gets worse after playing for a while... I've tried absolutely everything... I have to leave the PC on the desktop for about 30 minutes, and when I come back, the problem is gone. It can't be EMI in my case.
that is your room
What are you talking about?
your room cause your problems
Yes, I understand that, but what's so special about my room?
Post by Slender » 09 Jun 2025, 23:29
ZINZIRIO wrote: ↑
09 Jun 2025, 23:26
Slender wrote: ↑
09 Jun 2025, 23:25
ZINZIRIO wrote: ↑
09 Jun 2025, 23:22
Slender wrote: ↑
09 Jun 2025, 01:51
that is your room
If I knew I wouldn't be here.
you need try change pc / monitor location in your house.
ZINZIRIO
Post by ZINZIRIO » 09 Jun 2025, 23:32
Slender wrote: ↑
09 Jun 2025, 23:29
ZINZIRIO wrote: ↑
09 Jun 2025, 23:26
Slender wrote: ↑
09 Jun 2025, 23:25
ZINZIRIO wrote: ↑
09 Jun 2025, 23:22
I guess I'll try that, but I don't think moving the PC a few feet away will make any difference, other than the fact that I had the PC in the same place as it is now the whole time, I didn't have the problem.
Sirkiwi
Post by Sirkiwi » 14 Aug 2025, 20:59
I apologize, English is not my native language.
I also bought a 12V 100Ah LiFePO4 battery and was successful, but I discovered a few things along the way.
When my battery arrived, the first thing I did was charge it by plugging it into the wall. This gave me a smoother picture, but the input lag was still present somehow. I read in another post that an online UPS disconnected from the grid gave different sensations depending on the time of day it was recharged. This made me suspect that interference was somehow infiltrating the battery and affecting it in some way.
The next step was to go to my brother's house and recharge the battery there. He doesn't have any power issues at home. The next day, I went to get my battery, connected the inverter, and then my PC, and WOW! The input lag is gone. Everything works perfectly, 100% responsive, and my PC feels super fast at all times.
Now I'm saving up to get a hybrid inverter and a 500W solar panel to recharge my battery.
Nowadays, it's very easy and cheap to set up a 100% off-grid system.
Don't lose hope :)
sulaemulae
Post by sulaemulae » 05 Sep 2025, 04:05
You can also get 2 batteries and charge one from another without having to charge it somewhere else.
Somehow second battery gets way less 'noise' that way
