MSI OPTIX MAG251RX Review by RLCSContender
Locked
1000WATT
Re: MSI OPTIX MAG251RX Review by RLCSContender
Post by 1000WATT » 10 May 2020, 01:54
You don’t need to see an optometrist. You are already specifically annoying us. This forum is not called "stunningly accurate colors" or "chic viewing angles." And certainly this forum is not called "tn vs ips". The limit of condescension to you as a beginner has long been exhausted. And if earlier they tried to explain to you what you were mistaken, now you get one rudeness and disrespect.
Dirty Scrubz
Post by Dirty Scrubz » 10 May 2020, 02:06
RLCScontender wrote: ↑
10 May 2020, 01:32
3ms easily. there's no need to cope and think TN is still ahead. It ended the moment IPS released the MSi
LMAO yeah I'll stick to my original comment, go see an optometrist:
Before you claim I tried to pick a bad frame, I picked one of the best ones w/the ladders lined up. I'd hate to see how it does with the fullscreen crosstalk test. *shudder* Also, I bet your MSI's brightness was cut in half with that BFI enabled.
Edit: Here's a direct almost "apples to apples" comparison between a lowly TN and your mighty MSI:
Your superior IPS technology leaves a lot to be desired. Unlike you though, I still think the both TN and IPS have their own use cases in the market but IPS simply doesn't cut it for those that want the absolute best. It's made progress but it simply isn't there yet and most likely will get supplanted by other better technology (e.g. cheaper OLED at reasonable screen sizes).
axaro1
Post by axaro1 » 10 May 2020, 02:20
Dirty Scrubz wrote: ↑
09 May 2020, 21:56
Does anyone take this guy seriously anymore? I honestly recommend you go make an appointment with an optometrist because you are either blatantly trolling or have some serious medical issues with your eyes. I'm not even joking with you right now.
It look decent but not as good as I thought, there's some moderate overshoot, which is always visible on the UFO with the darker background and the black outline on the left side of the ufo is almost disappearing, I wonder if lower overdrives could fix the overshoot but the outline can potentially get even worse.
Can we have other pictures? the ufo on the bottom seems out of focus.
Slow Motion mode on the phone can come in handy for these kind of tests if you don't have professional equipment.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
1000WATT
Post by 1000WATT » 10 May 2020, 02:55
This will be the last attempt.
Some people on this forum preferred tn. I will not speak for everyone. As an owner of tn, I am annoyed by low contrast, shitty viewing angles and color rendition. And no settings and no color profiles can fix this. And I dream of 240 ips with the same blur level as the tuned nt. And for his sake I’m ready to spend $ 1.5k. But this unfortunately is not.
You take photos that you consider evidence. Tighten and make them according to the instructions. https://blurbusters.com/motion-tests/pursuit-camera/ It is not necessary to follow each item exactly, but item 11 is required.
You have a lot of experience with ips. I think you think a less blurry image is no longer possible.
But this is not so. calibrated nt.
And let people decide for themselves what is more important for them, blur, colors, angles.
Needless to say, there is no difference in blur between 240tn and 240ips. It’s not worth saying that this is not visible in games.
Once again, this forum is not a ips vs tn forum. Provide the right information and let people decide for themselves what is preferable for them.
This was my last attempt.
RLCSContender*
Post by RLCSContender* » 10 May 2020, 03:53
Good catch. I stand corrected, it definitely wasn't aligned correctly. That is an oversite on my part. But here's the one that is aligned.
RLCSContender*
Post by RLCSContender* » 10 May 2020, 03:55
Just lol at the kid who thinks i need to see an optometrist yet he can't even differentiate a straight line from an obvious alignment error on my part.
Oh the irony
Dirty Scrubz
Post by Dirty Scrubz » 10 May 2020, 07:57
10 May 2020, 03:55
Oh the irony
You either purposely skipped my post because I specifically show an aligned picture comparison and you couldn't handle it or it's that terrible eyesight of yours acting up again: viewtopic.php?f=2&t=6724&start=60#p50601
amezibra
Post by amezibra » 10 May 2020, 10:34
10 May 2020, 03:53
You think this is good MBR ? lol this is as fuzzy as my 144hz ips with gsync on, we dont even see the white notch separated. this is the worst MBR pict i have seen.
RLCSContender*
Post by RLCSContender* » 10 May 2020, 10:36
10 May 2020, 07:57
10 May 2020, 03:55
Oh the irony
No need to damage control
I made an obvious error and u jumped on it by believing it was actually an accurate ufo test of the MSI. If you cannot differentiate a very obvious error by not seeing that misalignment, then that is EVIDENT that u need to see an eye doctor.
And a brain doctor as well. Considering u get mad at ppl all bcuz "i dont agree with him, ima insult him bcuz i dont agree"
Anyway ima put u on my ignore list. Not gonna dignify replying to a 12 yr old who cannot keep a cordial tone.
RLCSContender*
Post by RLCSContender* » 10 May 2020, 10:39
Nothing short of beautiful
Locked
