Keep in mind. I'm no "MSI" schill. I'm not here as an affiliate marketer for them. As a matter of fact, i TRASHED the MSI Optix mag251rx since at the time, i had no other 240hz ips to compare it to. But upon trying out and testing every other 240hz ips monitor, i thought to msyelf "OMG, i had the best 240hz ips monitor, I can't believe i returned it". btw, i meant "faster" overdrive, what a dumb typo LOLForum Moderation Note wrote:EDIT by Forum Moderator Team: Threads on same monitor by same OP were merged.
The "MSI OPTIX MAG251RX Review by RLCSContender" post begins on Page 6.
march 31, 2020
viewtopic.php?f=2&t=6543
RLCScontender wrote: ↑31 Mar 2020, 15:24Just returned the MSI MAG251rx just now. It's a wide gamut monitor with no sRGB which is a major dealbreaker. i measured at 111% sRGB. The stand is pretty bad and clunky. If your monitor falls down, it will crack easily. not to mention the overly tacky gamer aesthetics and "esports"
The only redeeming factor is the response time and ridiculously low input lag This is by far the fastest IPS monitor i've ever tested. (it's way faster than my viewsonic xg270qg even with its variable overdrive). I used two sources to measure response time(Eizo and this website). Average g2g was a whopping 3.1ms(that is better than most high end TN monitors). This was measured at 80 overdrive at its 240hz refresh rate. Even on lower refresh rates, the g2g average never goes above 4ms. That means this is good for console gaming.
The backlight strobing is actually above average(yes, you can strobe at 240hz). I tried it and i didn't see much difference, except the screen got dimmer. I dont' see the point of using backlight strobing if your FPS is running above 200 on this monitor because it's already buttery smooth without it. i Truly belileve this is the fastest 240hz IPS monitor right now. Gaming aside, everything else is atrocious
Poor/clunky stand and bad ergonomics.
No sRGB mode to clamp the oversaturation. Everything will be washed out
HDR is crap, dont' even turn it on. It has about 1100:1 contrast ratio, but there will be a lot of input lag.
Monitor aesthetics is not visually pleasing whatsoever(especially with its tacky esports logo and color)
in terms of perfomance, this monitor delivers. However, i'm willing to trade a slightly less response time for srgb mode, better stand, etc because at this low of a response time, it's really imperceptible (especially among other 240hz monitors).
I don't recommend this monitor even as a side monitor for gaming because everything else outside of gaming is pretty bad. There are other monitors(it will probably be slower than the msi mag251rx but with better aesthetics, has sRGB mode, and better ergonomics, etc) because a slightly faster response time from 3.1 to 3.6 is negligible). . In general though, if i was NOT comparing this monitor relative to other high end 240hz monitors, this is a phenomenal. Then again, the 240hz 1080p market for IPS panels is starting to get competitive(and perhaps oversaturated).
Next up is the VG279qm. I purchased it through amazon and it's coming in a couple of days. Can't wait to try it out
