ExplodinFistz
Post by ExplodinFistz » 12 Jun 2026, 09:16
RealNC wrote: ↑
12 Jun 2026, 08:47
It doesn't matter if you force vsync in the driver or not. If vsync is used, Reflex or the "ultra" low latency setting will apply a VRR cap to prevent vsync lag when using g-sync.
Oh interesting. Then in my case reflex would be enabled. Low latency mode is turned off. It is curious though because in RTSS it says my optimal VRR cap is at 228 FPS, in contrast to reflex which configures it to be 225 for my monitor's refresh rate of 240 Hz. RealNC, you have the same XG27AQDMG monitor as me correct? What VRR frame cap does RTSS report to you? I guess reflex and RTSS calculate with different formulas which would explain the discrepancy.
Screenshot 2026-06-12 091036.png (65.67 KiB) Viewed 3826 times
Post by RealNC » 12 Jun 2026, 20:15
ExplodinFistz wrote: ↑
12 Jun 2026, 09:16
Yeah. Reflex uses this formula:
Hz * 3600 / (Hz + 3600)
RTSS uses something else.
knypol
Post by knypol » 17 Sep 2026, 09:57
What gives best effect in smoothness: gsync + vsync (NVCP) or gsync + rtss fps cap?
