Finding root cause/fix
perpe2334
Re: Finding root cause/fix
Post by perpe2334 » 18 Sep 2026, 18:26
MaleGigolo wrote:
18 Sep 2026, 18:13
perpe2334 wrote:
18 Sep 2026, 16:41
MaleGigolo wrote:
18 Sep 2026, 16:01
slader wrote:
18 Sep 2026, 06:24
yeah bro at this point the best thing to do for the people who believe its the body causing that issue is make a message to find a group of scientists who can analyze this problem but i think its gonna be very hard to find..
No scientist would take you seriously. The brain and heart do produce electromagnetic fields but they are extremely weak and there is no evidence that humans can naturally produce significantly higher frequency or stronger EM emissions capable of interfering with electronics. I'm more interested in the fact that body can act as an antenna and reradiate electromagnetic fields to nearby electronics and static electricity can also affect electronics through ESD so who knows.
The only way to find out would be to wear a Faraday suit or to build a DIY faraday cage with shielded gloves and play using a wireless mouse and keyboard. Something like this:
(AI slop)
link generator for pictures
You’re only thinking about the EMF aspect, and even with that approach, you also need to account for grounding.You’re completely ignoring the magnetic field here; a Faraday cage doesn’t prevent this.—such as the 50–60 Hz fields from electrical wiring, or other magnetic fields present in the environment you’re in.
Also, if you’re living in an environment where you’re constantly exposed to EMF, magnetic fields, electric fields, etc., you don’t actually know how these different fields affect your body. So doing an experiment under only these specific conditions doesn’t really tell you much. And since you’re not going to live the rest of your life under those exact conditions anyway, the whole thing is basically pointless.
Thanks ChatGPT
Can be grounded easily and there are ways to shield against magnetic fields as well just much more expensive and would require a different approach. I'm just sharing random ideas. If i had money to waste i would build something like this https://www.youtube.com/watch?v=_MaeJbd1xaM to at least document this problem even if no one is going to believe me just for the peace of mind.
Calm down, you don’t have to prove anything to anyone. I also think it’s related to the body. I only said that what you showed was incomplete. Even if you show that this works, you don’t have the option to use it like this for the rest of the time. Also, I use AI for translation; otherwise, I don’t share AI-generated information.
