esports 1440p 360hz displays announced
Discorz
VIP Member
Re: esports 1440p 360hz displays announced
Post by Discorz » 08 Nov 2022, 02:54
07 Nov 2022, 01:08
But the Vicious Cycle Effect kind of applies here where 1440p is motion-blurrier than 1080p at the same refresh rate (higher resolutions amplify refresh rate limitations).
Physical distance wise 1314pps would be ~1:1 comparison, not 1440pps. Which is non-integer 3.65ppf for 360 fps, meaning impossible to compare properly. At least in this case. So perhaps better keep it fixed to pixels for now.
Vicious Cycle Effect may apply for unscaled content but from my understanding it doesn't really apply for gaming. For example in case of identically sized screens with differing resolutions, lets say 27", one with 1080p and other with 2160p resolution, physical on-screen size of in-game objects would be identical on both. Same object on 2160p screen would just take up more pixels to size match. And after we increase DPI to match sensitivity on the two (so more speed) the blur on both display would be ~identical because moving object size is "bigger". Scaling up the image and speed proportionally results in proportionally scaled blur. It's just that blur detail/resolution is finer on tighter PPI. So Blur Busters Law still applies here but since we increased object speed and object size the blur stayed the same.
It's a wild one. TestUFO could use an update.
EDIT:
Added image as example, representative of 1080p vs 4k display in motion (gaming).
Vicious Cycle Effect - 100% vs 200% Speed and Size.png (1.73 MiB) Viewed 23090 times
Sync Track size if fixed.
munchie4000
Post by munchie4000 » 10 Nov 2022, 16:53
Why on earth is there no ELMB or ELMB Sync mode on the ROG PG27AQN? Anyone got a good explanation? I have the current model (270hz) and it works very well so I was looking at this one as an upgrade but will hold off until they make an OLED 27 inch.
Charging nearly £1.2k for an IPS gaming monitor without that seems insane to me.
Post by Chief Blur Buster » 10 Nov 2022, 17:06
Discorz wrote: ↑
08 Nov 2022, 02:54
There's many ways to visualize it (screenwidth/sec, inches/sec, screentime, pixels/sec, etc).
Some of the perception issue is not necessarily dpi, but the amount of time an object is seen on the screen for -- that determines the ability to inspect its motion blur for an equal length of time, as a difference between static resolution and motion resolution. This gets muddy when we've got ultrawides and non-ultrawides. But when it comes to screenwidth/sec and time-onscreen, 1920x1080 and 2560x1440 is the same from that visualization POV.
That being said, testers need the choice of how they want to visualize the test, /within reason/ -- as long as fairly disclosed. And preferably over multiple metrics.
Yes, TestUFO needs an update. In fact, we're working on one already!
Discorz
VIP Member
Post by Discorz » 16 Nov 2022, 15:33
PG27AQN vs PG259QN @360Hz-FPS 960pps.png (641.81 KiB) Viewed 24315 times
Post by jorimt » 16 Nov 2022, 19:10
Discorz wrote: ↑
16 Nov 2022, 15:33
^ Ultra-fast IPS seems to be quite a jump from Fast IPS at 360Hz, and appears to finally have caught up with that refresh rate, for sure. Its overdrive performance in that capture rivals what I'm seeing on my PG279QM at 240Hz in the same scenario.
Kyouki
Post by Kyouki » 17 Nov 2022, 03:32
That looks amazing, can't get my hands on one. Really miss 1440p. Thanks for sharing!
Discorz
VIP Member
Post by Discorz » 17 Nov 2022, 04:59
Considering how slow LCD GtG is evolving this is impressive for only one generation. Its lowest CAD on IPS so far. I'd like to see a cheaper "XG27AQN" model with same panel. That one would probably have ELMB/SYNC.
I wonder why they didn't tune the lower VRR framerate properly. Could of been much better.
VRR Performance, 1440p 240-360Hz.png (65.46 KiB) Viewed 24210 times
jasswolf
Post by jasswolf » 17 Nov 2022, 05:31
Discorz wrote: ↑
16 Nov 2022, 15:33
Going to be super interesting to see this up against next year's 240Hz OLED tech. Very close race.
evmadic
Post by evmadic » 04 Dec 2022, 06:40
I'm a bit confused about the Asus PG27AQN's 25" mode.
It's a cool idea for gamers that play both single player and competitive games, but the monitor's 25" native resolution is 2368x1332 as opposed to 1080p.
So if I buy this monitor and use both modes, what res will I run my competitive games at? I keep them at 1080p in-game and allow the display to scale the game to 1332p for me ? Won't that add input lag?
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
styhk
Post by styhk » 04 Dec 2022, 07:18
evmadic wrote: ↑
04 Dec 2022, 06:40
You can use both 1920x1080 and 2368x1332 in desktop/game
