Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Hyote
Re: Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Post by Hyote » 07 May 2025, 02:51
Bought the cable and it's a noticeable difference over the stock Zowie DP cable.
Post by Slender » 07 May 2025, 03:30
Hyote wrote:
07 May 2025, 02:51
dp 2.1 aoc?
Hyote
Post by Hyote » 07 May 2025, 04:12
Slender wrote:
07 May 2025, 03:30
Hyote wrote:
07 May 2025, 02:51
dp 2.1 aoc?
Yes, https://www.amazon.com/dp/B0D1DMBYGS
Hyote
Post by Hyote » 07 May 2025, 14:36
If anyone is still looking at this as a potential desync fix, it isn't. Only buy it if you think your current cable has input lag / signal issues and you need something thinner and more flexible for your setup.
JimCarry
Post by JimCarry » 07 May 2025, 15:20
Hyote wrote:
07 May 2025, 14:36
ok but ,if you have zowie and you see the diffrence between your stock cable and the dp cable you link from amazon,what if someone buys cheap aoc 240? then his dp cable is sh@t quality,i am thinking that when you buy monitor,cheap or expensive the dp cable is always cheap quality.
Hyote
Post by Hyote » 07 May 2025, 16:12
JimCarry wrote:
07 May 2025, 15:20
Hyote wrote:
07 May 2025, 14:36
I think it really depends on whether the company cares about the quality of cables. Like I mentioned earlier, the Nintendo Switch HDMI cable seems high quality, while most monitor cables are usually not. So AOC might have better stock cables than Acer or ASUS, regardless of not selling high-end products. These random Chinese cables can be risky to buy as well, because you can't find out if they got through any kind of quality checks and I haven't seen anything like fiber optic HDMI or DP mentioned anywhere else on the internet. For now I find it a good replacement for the inflexible laggy stock cable I had.
tattoo
Post by tattoo » 07 May 2025, 19:11
got a dp and a hdmi both good quality,no difrence on my 480hz asus...also the hdmi goes black for no reason evry 10-15seconds
Coldplayer
Post by Coldplayer » 08 May 2025, 04:50
Hyote wrote:
07 May 2025, 02:51
What was the difference over the stock zowie cable you got? Also which zowie monitor?
Hyote
Post by Hyote » 08 May 2025, 07:10
Coldplayer wrote:
08 May 2025, 04:50
Hyote wrote:
07 May 2025, 02:51
It feels like there is less input delay with the 2.1 fiber optic but it's barely noticeable. I also had problems positioning the monitor cable previously because of how thick and inflexible it was. I could put the new one further away from my PSU cable so that might be one reason. I have an XL2546.
