i thought you should only use usb 2.0 for both kb and mouseChief Blur Buster wrote: ↑16 Oct 2020, 00:29Houston, we have a problem.
Especially with 4000 Hz keyboards and 8000 Hz mice being used simultaneously.
I just helped someone solve a high-Hz USB performance interference problem between two high-Hz USB devices:
Problem: High-Hz poll performance interference between 1000 Hz keyboard + 1000 Hz mouseSolution: Serparate USB controllers and PCI bus lanes per 1 high-pollrate deviceMaxTendency wrote: ↑12 Oct 2020, 16:35While I'm pretty convinced that 8k hz mouse polling is going to be not only noticeable but also impactful , I'm starting to wonder how much keyboard polling will affect this. High keyboard polling has known to destabilize the mouse polling and vice versa.
For example this is a 1khz mouse polling on an optimized setup with a 125hz keyboard. As you can see the variance is quite little, barely 1hz.
This is the same mouse but the keyboard is wooting one set to 1k hz. All of a sudden the variance is 20hz. Looks like windows can't even fully handle 1k hz keyboard and mouse at the same time.
With keyboards now supporting 4k hz polling like the Corsair K100, I'm curious how will this affect the stability of 8k hz mouse polling. Seeing that a 1k hz keyboard is enough to destabilize a mouse set to just 1k hz, a 4k hz keyboard would probably trash the stability of a 8k hz mouse.Yeah, that was what I thought. Glad my recommendation helped!MaxTendency wrote: ↑15 Oct 2020, 20:58Small update, using the asmedia port for keyboard (the lowest one, right next to the usb-c port) while using top port for mouse seems to minimize if not remove the impact of high keyboard polling on the mouse polls.
Blue is the mouse and red is the keyboard. This combo provided the best polling, pic of polling attached below.
With ultrahigh poll rates, you really need to isolate to one USB chip (and/or separate bus lanes) per high-pollrate device.
PCI-Express USB cards are also another solution that can help this. Plug the keyboard into the motherboard USB, and plug the mouse into the PCI-Express USB. Or do do USB port roulette until you find jackpot. Keep the adjacent ports empty (port above/below a plugged-in high-Hz USB device) because they often share the same USB controller.
This would probably become a staple recommendation of the new 2020s-era "Blur Busters Mouse Guide II"
Until the motherboard manufacturers "keeps up with the Joneses" and have a dedicated-USB-chip keyboard port, and a dedicated-USB-chip mouse port for the 2020-2030s esports era of 4000 Hz keyboard + 8000 Hz mouse + >360 Hz monitors + RTX 3080+ framerates.
This Grand gaming computer upgrade supercycle is going to be very interesting. I rarely see so many concurrent upgrades happen. Those now seem to happen only once every 5-10 years, rather than every 2-3 years in the 1990s-2000s. We are seeing a major Vicious Cycle Effect tick-tock (multiple concurrent frequency upgrades).
TIP: Always put high-Hz keyboard and high-Hz mouse on SEPARATE DEDICATED USB CHIPS.
slava1337
Re: TIP: Always put high-Hz keyboard and high-Hz mouse on SEPARATE DEDICATED USB CHIPS.
X3D MASTER RACE
juhhh
Hi how can i do this type of testing myself? recently got an 8k keyboard and already have a 1k mouse so im curious how i can test this to get the best ports for me
juhhh
for now ive put my mouse into the 2.0 ports at the top of my case, and disabled my gamecube controller adapter when im not using it. this is just raw guessing though cuz idk how to test. io know ppl use mouse tester but the on i find from google search doesnt look like the results ppl r sharing here.
- sdrgfgf.PNG (16.47 KiB) Viewed 7296 times
DudeBeFishing
I got a M2 KEY A+E to 2Port USB2.0 card to try. I was just curious what the results would look like. Using MouseTester v1.6.1, there's no measurable difference between my motherboard ports. Below are the best out of 10 runs. There is some human error with moving the mouse.
https://www.aliexpress.us/item/3256807039923907.html
Controller: GL850G
https://www.mouser.com/catalog/specshee ... GL850G.pdf
Test PC:
CPU: 5700X3D
RAM: DDR4 3600 14-14-14
Motherboard: Asrock X570S PG Riptide
Mouse: Logitech MX518 Legendary 1000Hz
USB 3.0 (Keyboard Port)
STDEV: 0.00447733
STDEV: 0.00462326
STDEV: 0.00569325
USB 3.0 (Mouse Port)
STDEV: 0.00401490
STDEV: 0.00439810
STDEV: 0.00476411
M2 KEY A/E USB 2.0
STDEV: 0.00407920
STDEV: 0.00429155
STDEV: 0.00531364
Controller: GL850G
Test PC:
CPU: 5700X3D
STDEV: 0.00447733
STDEV: 0.00462326
STDEV: 0.00569325
STDEV: 0.00401490
STDEV: 0.00439810
STDEV: 0.00476411
M2 KEY A/E USB 2.0
STDEV: 0.00407920
STDEV: 0.00429155
STDEV: 0.00531364
