Zowie XL2546 not smooth on League of Legends
Byome
Post by Byome » 30 May 2022, 18:30
Hi guys I'm hoping you can help me with this new monitor I bought the Zowie XL2546.
Currently I get 600 fps on CSGO which I cap at 400fps and is buttery smooth at 240hz. However, League of Legends is not smooth on this monitor and I'm not sure why. I have to cap the game at 144fps as it creates problems if capped higher. Riot stated themselves that it is recommended to cap at 144fps due to poor optimizations with the game. If I leave it capped at 240fps it feels much smoother but I get these weird jitters which I think is due to the game jumping frames which is due to the poor optimization I think. Anyway, my problem is that I need to play the game with 144fps but it doesn't feel good. I can't really explain it but it just doesn't feel smooth even though I'm getting 144fps. The game feels much smoother when I turn on vsync but the input lag is unbearable. Before this, on my 120hz monitor, I wasn't having this problem at all. If im not mistaken, the monitor should behave like a 144hz monitor if set at 240hz with a 144fps cap. I also have a new ryzen 5600x which I don't know if that has something to do with it. Here are some things I have tried:
  • windowed/borderless
  • uninstalling gpu drivers and updating using ddu/cpu
  • dyac on/off
  • ama on/off
  • changing refresh rate to 144hz
  • capping fps at different values
  • capping fps at 144 with Rivatuner
Silver
Re: Zowie XL2546 not smooth on League of Legends
Post by Silver » 31 May 2022, 08:26
Try playing in fullscreen 144Hz if possible, 120Hz if 144 isn't available. What speed is your RAM running at? Do you have any background tasks running? Which GPU are you using? Have you tried raising the priority of the game you're playing in the Details tab of the Task Manager?
1000WATT
Post by 1000WATT » 31 May 2022, 10:29
This is a problem game. Rtts fps limit or Scanline Sync helps remove some of the jitter but adds input lag.
Falkentyne
Post by Falkentyne » 01 Jun 2022, 16:28
I use 165hz at 165 fps with scanline sync in RTSS and there's no problem whatsoever. There's also no problem with RTSS off and vsync enabled in league of legends manually.
