I picked this up because it was really cheap and my other 240hz is out for RMA. I can't find much info on it except for a displayspec sheet and a Best Buy listing. No formal or in-depth reviews from sites like Blur Busters or Rtings. There is 1 review on YouTube but the guy doesn't go very in-depth or test VRB and that's what I'm most interested in.
The XV271 Zbmiiprx was released in 2021 and has similar specs to the VG279QM (27" 280hz IPS) which was released in 2019. Given the 2 year gap, what are the chances that it is using the same panel as the VG279QM? And if it is, will VRB performance be roughly the same or can a different brand's implementation of backlight strobing be significantly different with the same panel? According to the HUB review of the VG279QM ELMB results were relatively mediocre and he recommended to not use it.
If you can answer these questions or if you have this monitor and can provide info on the VRB performance and/or panel that would be great.
https://www.displayspecifications.com/en/model/e776278b
https://www.bestbuy.com/site/acer-nitro ... Id=6462577
