1440p 165hz/180hz/240hz Panel IPS/VA
MSI MAG274QRF-QD ( IPS 1440p 165hz ) this is my actual monitor with very good color accuracy ( on Rtings this monitor have literally 10/10 in SDR Color Gammut and...yes it's pretty good ( but it's matte coating so i found this pannel just "ok" ) and in, terms of motion blur it's a 165hz IPS....it's not really good for me but it's the best that i've found for now...
Dell S2721DGFA ( IPS 1440p 165hz ) this monitor cause me headache because it's not perfectly flicker free ( you can check that also on Rtings ) and the motion is like the MSI MAG274QRF-QD, very meh ! and so much reverse ghosting with very strong matte coating that i didn't like
Samsung Odyssey G7 ( 1440 VA 240hz ) the only VA that i've tested and i don't want to go back on VA, i don't care about high contrast because on FPS we don't care and it cause some black crushed ( and with black equalizer a VA panel become useless...and i have don't really apprecied the color accuracy with little green tint that i didn't like, ghosting are ok ! and reverse ghosting too but i found that monitor are too dark and i don't like the curved...it's not like a don't want curved but i don't care.
Acer Nitro XV272UPbmiiprzx ( IPS 1440p 144hz ) too bad, motion blur are just bad/ some reverse ghosting.
LG 27GN850-B ( IPS 1440p 165hz ) literally a DellS2721DGFA like, waste of time.
LG 27GP850 ( IPS 1440p 180z ) same here...random 1440p 165hz wich "OC mode 180hz" but just perform like the Dell and the other LG...
1080p Panel IPS/TN 144hz/240hz
Dell S2522hg ( 1080p IPS 240hz ) literally one of the worst ( but not THE worst ) it's a generic 240hz IPS panel with horrible strong matte coating and it's so blurry and small ( i very don't like the coating of Dell/Alienware wich are too strong ! ), 1080p only and the color accuracy are very bad ( like all IPS 240hz you can check that on some review of Bijan Jamshidi )
Asus VG259QM ( 1080p IPS 280hz ) wich is clearly THE WORST for me, seriously, some reverse ghosting, the contrast is weird because ( yes like some monitors ) the black are very black crushed on some space on certains map of games ( COD Cold War / Apex Legends ) and the motion handling god...it's so bad, if you put the overdrive too high the reverse ghosting are horrible, and without the ghosting are horrible too, the color accuracy are the worst of all IPS that i've tested, the menu are very meh...i really don't like this monitor and the 280hz it's useless for me
HP OMEN 25X ( 1080p TN 240hz ) yes the monitor that "AXAION" ( hi if you read this ! ) have send too Techless and it's like that i wanted to test this monitor wich is in fact...very bad for me...the colors are like some TN ( very very bad ) the motion handling are...not that good ( even with Blur Buster moving test in some overdrive it's one of the best but not the best ) because no saturation of colors, and the black equalizer and contrast handling are just horrible, i can't see anything when the ennemies are in shadows, i really didn't like this monitor.
BenQ XL2540 ( 1080p TN 240hz ) Just a useless BenQ now, this monitor have bad motion handling and poor overdrive handling ( reverse ghosting handling ) in comparison of other BenQ so just, it's useless now.
BenQ XL2546K ( 1080p TN 240hz ) good, but for the price i prefer my MAG274QRF-QD wich is 1440P Quantum Dots 27 inch display and for me another BenQ are better...
BenQ XL2540K ( 1080p TN 240hz ) THIS ONE are the best BenQ for me, same panel like the XL2546K but cheaper and with little trick you can enable DyAc !
MSI MAG251RX ( 1080p IPS 240hz ) another random IPS 240hz wich is literally the same like the S2522HG...so..useless and perform lower than the XL2540K.
Asus ROG Strix XG259CM ( 1080 IPS 240hz ) apparently the same panel according to Viewsonic "XG2431" but i have found the size too little and not perform very well ( especially like in shadow environement ) like the Viewsonic XG2431 but yeah...i can't take the XG2431 because just not in my country...very sad.
Alienware AW2521HF ( 1080p IPS 240hz ) The overdrive handling on this one are horrible / colors too, red are oversaturated and ( it's just not red...but weird orange ? ) and cause me some headache, very strange but the panel are not for me... + some weird artifact with the second and mostly the latest overdrive settings.
and i have tested some Viewsonic / AOC and other in 1080p 27 or 24 inch 144hz it's been some years and i didn't like too and we didn't care about their.
I know i'm very rude and pernickety but hey we are monitor enthusiaste and i'm very pernickety in terms of motion handling, the only monitor that i found "good" it's the BenQ XL2540K and it's cost only 300 euro but it's TN panel.....
My question here are, there is a good 1440p 240hz that is better in terms of motion handling than my MAG274QRF-QD ? because yeah...i have played so much years on a Alienware AW2521HF ( TN 1080p 240hz ) and when i look 165hz panel on my FPS games it's hurt !
i don't like backlight strobing technologies and i don't want 360/390hz panel because i play Apex Legends and i prefer 240hz ( with RTX 3070 )
did i'm stuck with BenQ TN again ?!
