Can i limit 60fps on 75hz monitor?
skyline86
Post by skyline86 » 26 Sep 2022, 21:15
Hi! I'm a new member from Vietnam! I'm using 24 inch monitor 75hz refresh rate gsync compatible. I want to cap 60 fps for all aaa games. Now my setting in Nvidia control panel:
-limit framerate: 60 fps ( or i use rtss frame limit at 60 fps)
-gsync compatible for fullscreen
-vsync on
-my monitor refresh rate at 75hz
Is my setting correct for gsync compatible? Thanks all for your help! Sorry for my english!
Re: Can i limit 60fps on 75hz monitor?
Post by Chief Blur Buster » 26 Sep 2022, 21:23
Yes, this is correct procedure for 60fps via 75Hz G-SYNC.
This is much lower latency than 60Hz VSYNC ON, and the only way to reduce "60fps" lag further is a higher max Hz for the faster-scanout of 60fps frames...
skyline86
Post by skyline86 » 26 Sep 2022, 21:28
Thank you for your reply! This mean my settings in nvidia control panel is correct?
skyline86
Post by skyline86 » 26 Sep 2022, 21:34
Do i need turn on vrr in windows 10 graphics settings?
Post by RealNC » 27 Sep 2022, 13:19
skyline86 wrote:
26 Sep 2022, 21:34
I believe this only affects games from Windows Store.
